Today's Solar Features in High Res & Wide Field | Mega Thread | Feb 23rd 2021
- Has thanked: 1182 times
- Been thanked: 1376 times
Hey all,
I finally got a morning with minimal clouds, and fairly good weather. It's been dreadful for months. Seeing was decent, not supreme, but quite good, getting into sub-arc-second seeing all morning and averaging a few peaks in the 0.8 arc-second range which allowed some higher resolution attempts. I didn't get to the maximum of the potential of the aperture, but was getting decent data at least which is better than I've had in a while with the storm conditions. I left the high res stuff soft processing wise. The big prominence field is gorgeous. The AR's are crackling with small flares and activity, some were so fast they changed in moments while watching.
Colored:
B&W:
Seeing Conditions (decent, getting sub-arc-second often enough, most images were around 0.8 arc-seconds):
Equipment:
C8 Edge + Full 214mm D-ERF + Baader Red CCD-IR Block Filter (2nd D-ERF) + PST etalon + 10mm BF + ASI290MM
++ As above, minus the etalon and BF for the photosphere imaging
100mm F10 masked Refractor + Baader Red CCD-IR Block Filter (2nd D-ERF) + PST etalon + 10mm BF + ASI290MM
60mm F16.7 masked Refractor Baader Blue CCD-IR Block Filter (2nd D-ERF) + Lunt Cak & Altain Astro 395nm + IMX253 (discs)
Colored:
B&W:
Equipment:
- Has thanked: 9696 times
- Been thanked: 5761 times
Re: Today's Solar Features in High Res & Wide Field | Mega Thread | Feb 23rd 2021
Hi Marty,
Well done
Well done
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Super set Marty!
Dan
South central Indiana
USA
USA
- Has thanked: 9298 times
- Been thanked: 6133 times
Top shots, Marty, thank you for sharing them.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Excellent presentation Marty, well done.
Martin
Martin
- pedro
- Has thanked: 14 times
- Been thanked: 6686 times
- Has thanked: 20757 times
- Been thanked: 10445 times
A very impressive collection Marty, glad you got to use the 200mm!
- Has thanked: 17823 times
- Been thanked: 16954 times
WoW Marty. You take the prize on these. That big prom reminds me of a furry animal nose down feeding on the spicule grass with a tail out behind it.
All of these are superb. You have the sun covered today!
- Been thanked: 4407 times
Outstanding work there Marty...well done
- JochenM
- Been thanked: 1619 times
Well, looks like you certainly took advantage of the opportunity. Impressive amount of very good images there, Marty.
- Has thanked: 8523 times
- Been thanked: 8262 times
You've been busy in the better weather, Marty. A really great set of images.
- Has thanked: 17925 times
- Been thanked: 8895 times
