Calcium Sun - 6th April
Has thanked: 4057 times
Been thanked: 1780 times
Tuesday offered a shift in wind direction for me, more north westerly, and experience tells me that despite MeteoBlue saying 3" seeing it would be locally better. This direction often brings cumulus clouds, and the blue gaps in between the clouds often offer some decent seeing. This was confirmed when I started off with the CaK full disk at 60mm f16, and a considerably more stable view than of recent days.
ImageCaK-FD-bw by Mark Townley, on Flickr
ImageCaK-FD-colour by Mark Townley, on Flickr
Today also offered a chance to continue my CaK triple stack journey, I tried a few configurations i'd thought of the previous evening. Whatever I try I get consistently better results in double stack, and using the sky bender I am able to tune the second filter of the stack to give maximum contrast which in turn reveals the chromospheric fringe and proms. Double stack also has about 3-4 time shorter exposure which when fishing in the better moments of seeing is a must...
Deciding to chance it I went for 100mm f28 with the IMX174, and taking 4000 frame captures figured there would be enough good sub frames to make a decent image: Firstly departing AR12813... All closeup images have a decent amount of zoom left in them, so double click for the view in Flickr.
Imagear12813-CaK-bw by Mark Townley, on Flickr
Imagear12813-CaK-colour by Mark Townley, on Flickr
And the decaying area of plage, yesterday had several pores, but was struggling to make them out today...
ImageMagnetic-active-region-CaK-bw by Mark Townley, on Flickr
ImageMagnetic-active-region-CaK-colour by Mark Townley, on Flickr
On the north east limb there was more plage but was struggling to get a decent view of this one.
ImageEast-patch-cak-bw by Mark Townley, on Flickr
ImageEast-patch-cak-colour by Mark Townley, on Flickr
Then, just to be silly, and because i'm testing out a couple of different optical configurations, I went for 100mm f46, again with the IMX174, I knew seeing wasn't up to it, so increased the frame count to 6000 with a view of stacking only the very best. Some silly colour just for fun too!
ImageNE-limb-cak-close-bw by Mark Townley, on Flickr
ImageNE-limb-cak-close-colour by Mark Townley, on Flickr
Imagear12813-cak-close-bw by Mark Townley, on Flickr
Imagear12813-cak-close-colour by Mark Townley, on Flickr
Then this cheeky little number came out of stacking, looks like there is some potential for this when in the constraints of the seeing...
Imagemagnetic-region-CaK-close-bw by Mark Townley, on Flickr
Imagemagnetic-region-CaK-close-colour by Mark Townley, on Flickr
Quite pleased with the last closeup, definitely my favourite from today and worth the full size view. I want to see if I can get somewhere around f40 for slightly better sampling. More CaK experiments for tomorrow assuming the blue skies carry on a bit more.
Hope you like.
EGRAY_OBSERVATORY
Been thanked: 1653 times
Re: Calcium Sun - 6th April
Post by EGRAY_OBSERVATORY »
You certainly are working-hard to try out these experimental set-up's Mark. And in the cold too. Better you than me. Even the possibility of some snow in the SE, as has occurred in SW-Holland According to my Daughter there and with our temps today around 6 to 8-degsC, you are brave...
The close-up's of AR2813 are my favs - even though decaying as it nears the limb.
Cheers
Terry (in the warm)...
dhkaiser
Has thanked: 902 times
Been thanked: 745 times
Post by dhkaiser »
Impressive results Mark.
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
Has thanked: 3734 times
Been thanked: 1492 times
Oooh these make my mouth water, especially the last few shots :bow :hamster:
Has thanked: 1656 times
Been thanked: 1501 times
Really excellent, Mark. Your Tinkering is working wonders. Congrats on SPoD :)
