Alexandra: I hope it is OK to post few moon images on Sunlit Earth
The two close ups were done with the HaT at full focal length and the ZWO 174 camera: Frederic says the scope should resolve objects less than 1 Km wide. The disk was taken with an Evostar 72mm and the ZWO 178 camera: I think it is a good match of scope and camera.
Moon views on August 30th, 2020
Moderator: Montana
- Has thanked: 9327 times
- Been thanked: 6163 times
- 204614 Tycho.jpg (894.36 KiB) Viewed 983 times
- 204650 Mare Crisium.jpg (931.18 KiB) Viewed 983 times
- 212334 Moon disk.jpg (931.48 KiB) Viewed 983 times
- Has thanked: 8559 times
- Been thanked: 8297 times
Re: Moon views on August 30th, 2020
Beautiful reflected light images, Franco. Very nice.
- Been thanked: 8907 times
Of course Frank, it is reflected sunlight
These are absolutely incredible, especially the second photo as I feel I can reach out and touch the Moon
- JochenM
- Been thanked: 1619 times
Excellent results there, Franco. Looks great!
It looks like you might have slightly blown out (overexposed) the middle crater in the second image (Proclus I think?). That's always tricky to get right and pick up on high(er) resolution lunar images though. I personally use the preset/filter in Sharpcap that highlights overexposed areas to get my exposure just right. Not sure if Firecapture (if that's what you're using) has something similar.
Thank you Stu, Alexandra and Jochen for your nice comments. Jochen: I probably brightened up too much the second image as Mark T told me the last moon images I posted showed dark on his monitor. I will replace when I have a chance.
Excellent effort Franco.
With our Sun being relatively quiet, it's good to see what else can be imaged so well as yours.
Thanks vm
Thanks vm
Adding this two image mosaic to the series...
- Moon mosaic final.jpg (1.07 MiB) Viewed 915 times
