Harvest Moon 1st October 2020
Moderator: Montana
- Has thanked: 8418 times
- Been thanked: 8162 times
Images of the Harvest Moon in colour and monochrome using a Nikon D5500 operating in video mode, Technosky 125mm f7.8, Powemate 2.5x and 50mm extension tube. Multiple video files (12 pane mosaic) were converted to SER files using PIPP, stacked using AS!3 and combined using MS-ICE into a single weak colour image. The RGB component channels were then separated out and processed in ImPPG to sharpen each one individually before being recombined into a single, sharpened, colour image. I used PixInsight for colour separation, recombination and enhancement.
Here are the results.
Enhanced colour...
20201001_Harvest_Moon_Colour2 by Stuart Green, on Flickr
Mono for comparison...
20201001_Harvest_Moon_Mono by Stuart Green, on Flickr
The Nikon doesn't really produce high quality images, but it's the only colour camera I have at the moment. I was just so glad the sky remained clear, for a while at least, during the session.
Thanks for looking.
Enhanced colour...
Thanks for looking.
- Been thanked: 6577 times
Re: Harvest Moon 1st October 2020
Hi Stuart,
You were very lucky to even have seen the Moon and especially to get such a fine image.
The colouring and the mono version is fab.
Thanks for sharing
Thanks for sharing
- Has thanked: 9145 times
- Been thanked: 6025 times
A lot of work involved, but the results are worth it, Stu. Super.
Filipe Alves (a Portuguese amateur) published an article in Sky & Telescope in 2005 | Sky and Telescope, volume 110, number 7, page 120 and describing:
How to capture the colour of the Moon
by Filipe Alves
http://www.joaogregorio.org/blog/links/ ... ipe-alves/
Interesting stuff
by Filipe Alves
Interesting stuff
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Excellent images.
Though the first appears to have a rust problem.
Nothing a drop of WD40 won't cure.
- Been thanked: 8791 times
Wonderful images Stuart
This is definitely on my list of must do over the winter, it would be nice to do from my bedroom window I think
I love Rusted comment
Thanks for the link, Pedro. Much appreciated.pedro wrote: ↑Fri Oct 02, 2020 1:24 pm Filipe Alves (a Portuguese amateur) published an article in Sky & Telescope in 2005 | Sky and Telescope, volume 110, number 7, page 120 and describing:
by Filipe Alves
Interesting stuff
Hi Alexandra,
I’ve been waiting some time to capture a full Moon image in colour, so I was really pleased when the Harvest Moon showed itself from behind some hazy clouds for 30 minutes or so.
Regarding the rust... I did try to retain a more balanced colour pallet, but I ended up with a blue edge at the top and a green edge along the bottom of the image. I think there are some improvements to be made to the optics, maybe. I’m going to try reprocessing to see what improvements can be made on the processing side.
Many thanks for the link Pedro, which I will try out on my last Lunar imagery session.
Here's a further colour enhanced version. This time I just worked with the image 'out of camera' (after stacking and creating the mosaic), increasing the colour saturation, deconvoluting and sharpening in PixInsight. A bit of a blue tinge around the top edge
20201001_Harvest_Moon_Colour by Stuart Green, on Flickr
- Been thanked: 4340 times
A great full moon shot Stu, and the enhanced colour versions add a new dimension to a target we usually consider cold and grey !!!
Many thanks, Terry and Brian.
