Starlight from a few million light years away
Lets brighten up peoples live with all those lovely pictures of the world around us!
Moderator: Montana
Has thanked: 10 times
Been thanked: 521 times
Post by MapleRidge » Tue Nov 17, 2020 2:14 am
Hi all...
I'll take a chance and post this anyway, but no sunlight in the traditional sense in this pic at all :lol:
I finally got around to trying my hand at deep sky again after many years of promising to get back to it. I took a few test images over the past few months to figure what will work and what needed to be tweaked and finally made an effort on Saturday night.
This image of M33 was taken with my Stellarvue 110 with a focal reducer/flatter (around f5.6), and Ha modded Canon 60D camera on the Takahashi EM400 mount. An Optolong L-Pro filter was also used. Exposures under 3 mins seem to track ok, so no auto guider was used. The image is a stack of 30 x 125 second exposures, which were processed in Images Plus to calibrate dark and flat frames, stack the images and apply a digital development filter. The final stacked image was adjusted in Photoshop to tweak the brightness and contrast.
The edges of the field show distortion of the stars...should have cropped it a bit, but this is the full frame.
With winter coming and planetary targets getting scarce I figured I better put all the deep sky equipment to work and keep me occupied once the sun sets in the coming months :lol:
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, OAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
Has thanked: 1210 times
Been thanked: 1027 times
Re: Starlight from a few million light years away
Post by Carbon60 » Tue Nov 17, 2020 6:27 am
Looks great, Brian. I’ve never tried any deep sky imaging, but worth considering with the longer dark nights in the north.
Has thanked: 2910 times
Been thanked: 1099 times
Post by Montana » Tue Nov 17, 2020 8:15 am
Well done Brian! that's a fantastic achievement :hamster:
I have only done DS imaging once last year when I stayed with Andy in Spain. We stayed up all night chatting for a week and I learned loads. I have the deepest respect as it is a completely different way to solar and planetary. I just don't have the equipment to be able to do this at home :bow
Post by MapleRidge » Tue Nov 17, 2020 2:35 pm
Stuart and Alexandra...
Thanks for your feedback on the M33 image :bow
Alexandra, I would think you could do some deep sky (you have the mount, scope and camera), but maybe the light pollution is a bigger issue than hardware?
8' Diameter Dome
highfnum
Been thanked: 113 times
Post by highfnum » Tue Nov 17, 2020 10:05 pm
pretty
Post by MapleRidge » Tue Nov 17, 2020 11:46 pm
Thanks John!!!
8' Diameter Dome
Post by Montana » Wed Nov 18, 2020 8:08 am
Brian, my mount is nowhere near set up properly for accurate tracking, I also don't have a guide camera either. It would be way too complicated and time consuming to set up in a cold dark garden each time. Accurate tracking set up is OK if it is permanently mounted, the time investment is worth it but not if you have to set up each time in a garden. I would probably spend about 2 hrs setting up and then it would be cloudy. The light pollution is also very bad here, the sodium filter blocks most of it but all street lights have now been switched to LEDs over the last couple of years ;)
rsfoto
Has thanked: 1925 times
Been thanked: 1419 times
Post by rsfoto » Wed Nov 18, 2020 5:18 pm
WOW, LED light is a DSO killer. It has far too much blue and the intensity is overwhelming. Look below what happened in my town. They installed LED light a few weeks ago and now it looks like a football stadium on the street. My Sky has gone down the drain ...
I have a SQM running and before the LED I was reaching near 20 mag and now I barely reach 19 mag per square arc second ...
Right image January 2018, Left image 2 weeks ago. You can see the date on the right lower corner in each image of my All Sky camera.
Post by MapleRidge » Thu Nov 19, 2020 3:46 am
Alexandra, certainly a lot of obstacles for you to attempt the deep sky...sad news.
Rainer, that is quite an increase in brightness. Are these new lights not well shielded? There has been a moderate change over in a few cities locally and they seem to have reduced the sky glow (base don before/after pics).
8' Diameter Dome
Post by Montana » Thu Nov 19, 2020 11:58 am
Rainer, I took a 5 second image of the Milky Way from my house last night, the camera has a sodium filter block on it but my image looks just like your left hand one :( will have to dig it out of the camera tonight.
rsfoto
Post by rsfoto » Thu Nov 19, 2020 5:02 pm
Hi Brian,
In my case it has nothing to do with shielding the LED lamps. The street is concrete, not black asphalt, and is very bright and blue light reflects nicely on this. Then add the humidity in the Air ... as well as add the lamps of the neighbours shining up and you got the perfect Light Pollution ...
No way of speaking with the neighbours as they are afraid of the dark and when they go into vacations they light up their houses 24 hours a day so the robbers do not get in ...
:o
Post by Montana » Fri Nov 20, 2020 7:31 pm
I processed my image from the other night, I couldn't do more than 5 second exposure
(Testing my new Sigma 10mm f2.8 lens. Stacked 1 min 40 secs (20x 5sec images) at ISO6400)
ImageFull sky 2020-11-18 by Alexandra Hart, on Flickr
rsfoto
Post by rsfoto » Fri Nov 20, 2020 7:38 pm
Hi Alexandra,
Very nice but it is all relative. What was the lens, the aperture, the ISO and the resulting speed ?
Thanks ;)
KMH
Has thanked: 3 times
Been thanked: 12 times
Post by KMH » Sat Nov 21, 2020 2:59 am
Brian,
Beautiful image!
Kevin
