Conjunction 20th December
Moderator: Montana
- Has thanked: 20819 times
- Been thanked: 10489 times
Did a rare bit of night time astronomy, I guess a 1 in 800 year conjunction is worth a shot. I used my 'new' 177/1200L refractor from Bresser, a 1.6x magnimax barlow and the FLIR IMX174 grasshopper camera. I stacked 512 out of 4000 and coloured sepia.
conjunction by Mark Townley, on Flickr
I got the scope principally for solar, and will likely run it in a 120/f10 configuration and will reserve it for CaK when the seeing is excellent and i'm able to use the 200mm HaT for Ha work. I looked visually at the moon and there was a lot of blue halo which may not bode well for CaK, but it will be several more months before the conditions allow me to properly test it.
All good fun!
All good fun!
- Been thanked: 8906 times
Re: Conjunction 20th December
Wow!! that's incredible Mark
I didn't even try, I sat for an hour looking through my upstairs bedroom window and just soaked up the view and atmosphere, magical!
- Been thanked: 4900 times
Excellent capture Mark and hopefully if the clouds stay away from here (I doubt it), will at least have a look tonight.
Thanks for sharing
Thanks for sharing
- Has thanked: 99 times
- Been thanked: 121 times
Managed a snap through the 120mm refractor during an unexpected lull in the clouds.
Nothing special about the photo, but as you say Mark...... once in 800 years has gotta be worth the effort!
Les.
Les.
- IMG_6691 Jup & Sat 120mm refractor.jpg (3.04 MiB) Viewed 852 times
8" SkyWatcher reflector on HEQ6. 10" Meade S/C & 16" Meade reflector awaiting obsy "planning permission"!
Coronado PST & Lunt Herschel wedge for 120mm SkyWatcher refractor on EQ4.
Graves meteor detection system.
Canon 70d & ZWO ASI120mc for imaging.
Photoshop skills questionable.
Nice captures, Mark and Les!
I was also lucky to capture Jupiter and Saturn, on Saturday already, through thin clouds and very close to the horizon, of course. Clouded out since then and probably for the coming days, but I'm happy I could get two videos (with different exposure times for planets and moons, the image is a composite of both) and also ten minutes of observing with binoculars.
Kind regards,
Frank
Kind regards,
Frank
- rsfoto
- Has thanked: 9723 times
- Been thanked: 5773 times
Well done
- Has thanked: 9326 times
- Been thanked: 6157 times
Lovely shot, Mark ! We may see it today, not very likely, or tomorrow, more likely.
We still have 25cm of snow on the ground here and it does not seem to be melting anytime soon. That makes it a bit more complicated to take out a large scope, so I may try to observe with the Evostar 72mm and a 5mm TV eyepiece.
- Has thanked: 8559 times
- Been thanked: 8291 times
Nicely done, Mark.
Clouds here just in the wrong place at the wrong time.
Nice shots Les and Frank!
- Been thanked: 4428 times
Great images of the conjunction
Nice to see them, as the 18th was my only clear night so far.
