Hello everyone...
I have a few more images from Mondays session. I originally posted the full disk, but here are the longer focal length images. All images use a Lunt LS80T/DSII/B1200Ha + 2x teleconverter + Infinity 2-1M camera.
To start, the three AR's on the eastern part of disk...AR1428, AR1429 & AR1430. This is tuned to where I thought the greatest activity was seen aroudn AR11429.
Due to the cold temps, I had a lot of fiddling with the preessure tuners, and found this had a nice combination of sunspot details and the small bright features. This has poor contrast, just posting to show the difference to the above image.
Last, I have the western disk with AR1423 approaching the limb.
Now, the bigger hole I have dug for myself involves the attempt to animate 2.5 hrs of images (54 I think). I finsihed one AVI off last night but it is huge...100+ MB. Just wondering what software folks are using to generate the animations to get some form of compression to drop the imgae size. I generated it form MaximCCD, bu thsi is the only program I have to generate animations. I need to do some cropping as the frames jump around as it stays locked on the AR, so that will reduce it as bit. Any suggestions?
Thanks,
Back to images from March 5th
- Been thanked: 4340 times
Re: Back to images from March 5th
Hi Brian
very fine shots. You dug the hole, you jump in it, there is no way out of it
Has the second shot some newton rings ? It looks a little bit unusual to me
Hi Walter...
I'm still in my hole...AVI file too large to upload...or so it seems. Will keep working at it.
I also noticed the bands in the one ime, and they are in many others but no where near as prominant. I took them as newton rings as well. So long as they stay fairly inconspicuous I am not going to worry.
Thanks,
Thanks,
- depes
Hello Brian
Here we can see a new setup.. and interesting pictures from the our Star...
I believe that it is the right time to use also my LUM Skynyx 2-0C...
Regards
Regards
- Been thanked: 10248 times
Top shots Brian!
- Been thanked: 8793 times
Lovely pictures! nice to see the off band comparison.
Regards
Regards
