Two photos of the same group 0.7A and 0.5A. 150mm scope.
Has thanked: 13 times
Been thanked: 79 times
Post by Valery » Sat Mar 29, 2014 6:49 am
March 24 I decided to compare how the solar surface will be seen through the same 150mm telescope equipped with
single stack 0,7A and double stack 0,5A.
Here are two these photos. 0,7A ones looks consisted more fine details, while 0,5A looks more relief defined.
Two reasons 0,7A has finer details: this bandwide has leak from the continuum and we can see some surface
details and exposure time is much shorter - better atmosphere freezing.
To improve details in 0,5A I need to remove one or both pre-filters on etalons.
Thanks for looking.
Valery Deryuzhin.
Re: Two photos of the same group 0.7A and 0.5A. 150mm scope.
Post by Valery » Sat Mar 29, 2014 6:50 am
Here is 0,7A
Has thanked: 1199 times
Been thanked: 490 times
Post by marktownley » Sat Mar 29, 2014 9:02 am
An excellent pair of comparison images valery, always a pleasure to see your shots. Definitely remove the pre filters on these etalons, what ERF do you use - front end full aperture or a sub aperture ERF in the tube?
Post by Valery » Sat Mar 29, 2014 11:20 am
marktownley wrote:An excellent pair of comparison images valery, always a pleasure to see your shots. Definitely remove the pre filters on these etalons, what ERF do you use - front end full aperture or a sub aperture ERF in the tube?
Thaks Mark, I do use subaperture D-ERF applied on the front collimation lens.
Derek Klepp
Been thanked: 88 times
Post by Derek Klepp » Sat Mar 29, 2014 9:39 pm
An interesting comparison
sullij1
Post by sullij1 » Sat Mar 29, 2014 11:46 pm
Valery, beautiful details! Just a Photoshop suggestion, with such detail in the umbra in the .7 image, try masking in the umbra details from the .7 into the .5. This will get the best detail from both images. just a suggestion to make gorgeous images even better.
Look Up!
Post by Valery » Sun Mar 30, 2014 6:15 am
sullij1 wrote:Valery, beautiful details! Just a Photoshop suggestion, with such detail in the umbra in the .7 image, try masking in the umbra details from the .7 into the .5. This will get the best detail from both images. just a suggestion to make gorgeous images even better.
Joe, I am not familiar with all these PS tricks and, honestly, have not enough time to spend it for such images improvements. :^)
Valery.
Pragmatist
Has thanked: 1 time
Post by Pragmatist » Sun Mar 30, 2014 6:21 am
Wow, impressive images.
Lunt LS60THa. B1200. Pressure tuner. Solar searcher. Various eyepieces.
solar
Post by solar » Sun Mar 30, 2014 6:56 am
:bow :bow :bow
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 12", C8 CG5, Megrez80, SBIG2000 MXC,
PGR 2.8 Grasshopper PGR Flea3, DMK21 ASI 120mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
Has thanked: 1047 times
Been thanked: 360 times
Post by Montana » Sun Mar 30, 2014 5:30 pm
My ...! these are good :bow :bow :bow
p_zetner
Has thanked: 3 times
Been thanked: 68 times
Post by p_zetner » Sun Mar 30, 2014 5:46 pm
Very beautiful and informative comparison, Valery.
What would (slightly) off-band imaging look like with the double stack (0.5 A)? High contrast with more photospheric detail?
Peter.
Post by swisswalter » Mon Apr 07, 2014 4:35 am
Hi Valery
fantastic job. Thanks for sharing and explaining
