150mm scope, Double Stack 09 01 2014
Hi all,
Today was a good day for sun imaging - enough dramatic details and fair seeing.
SkyWatcher 150mm F=750mm refractor + Aries Solar kit + LS50F etalons + PGR Flea3 ICX445 camera
200 frames out of 1240 for each photo. Astar Image 3.0 + CS6
Thanks for looking.
Valery.
Thanks for looking.
Valery.
- michael.h.f.wilkinson
Re: Sept. 1 2014, 150mm scope, high resolution close up.
Great work. No luck observing the sun here, alas
- Been thanked: 171 times
Valery, top notch stuff. I always wonder when processing weather or not to make the flareing regions pure white to illustrate the drama of the sun, or to dim them down to stay unclipped. What are your thougths on this?
Chris Schur
- Been thanked: 16 times
Hi Valery
a very fine transparent filament
Cschur wrote:Valery, top notch stuff. I always wonder when processing weather or not to make the flareing regions pure white to illustrate the drama of the sun, or to dim them down to stay unclipped. What are your thougths on this?
I use both ways - depends of the "landscape dramatism". However when they are pure white, you have largest dynamic range for other details on the screen.
Valery.
Re: 150mm scope, Double Stack 09 01 2014
Good work as usual Valery.
Ted
Ted
- Been thanked: 10489 times
Top notch images valery!
- mr40mm
I really like your work.
Astro-Physics 152mm F8 with 1200 mount, SkyWatcher 100mm F10, Celestron C-8, Baader Herschel Wedge Model P, DayStar Quantum PE .5 Angstrom, PGR FLEA-2 CCD video camera, Meade 14" RC with Astro-Physics 1200 Goto mount.
Thank you, guys for your kind words.
Valery.
Valery.
