Hi all...
I have been having ongoing issues with the ZWO174MM camera when I try to connect with a longer cable...need 3-5m to reach the scope from the spot that the PC is parked in the observatory.
If I run on the short cable as supplied with the camera all is good. No matter what setting I use in the setup of the USB speed in FireCapture the camera either looses connection immediately or is not recognized at all. I have been running it on a powered multiport hub (USB2) but it is very slow (but stays connected).
Has anyone had similar problems? My thought was to get an 'active' USB3 extension or upgrade the hub to a powered USB3 version...just hate to spend money and not solve the problem.
Any thoughts or suggestions would be most welcome.
Thanks,
ZWO 174 connection problems
- Been thanked: 4340 times
Re: ZWO 174 connection problems
Hi Brian
sorry to hear about the problems. What ever the reason is, I would get a powered USB3 hub
- Oh, I get it now!
Hi Brian,
I can confirm this problem. My 3m USB3 cable (not a cheap one) causes a lot of lost frames. The original (short) cable supplied with the camera works fine.
Has anyone success with a powered USB3 hub? The short cable is really inconvenient to use.
Thanks in advance for any information!
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Brian,
Could you share the outcome of testing with a powered hub?
Alfred
Alfred
Thanks for all the posts on this...
I have yet to order a hub...just too busy, but hope to get that done tonight if I can.
The short cable would be OK if I used a laptop and could set it up next to the scope, but that does not work well the way I have the observatory setup. I will be sure to post any results once I get a chance to try a powered hub or active extension...just see hwo much $$$ I want to spend on experiments
Hi Brian
you can not spend too much money with new experimental gear
RTJoe wrote:Hi Brian,
Grüezi Joe
welcome to that wonderful site. Have fun in the sun
- The Sun?
USB 3 is a spec for a high speed serial link and that camera certainly pushes a lot of bits.
The problem is that every cable has some parasitic electrical properties and the longer it is, the worse they get.
The data starts off as a square wave but with the capacitance, resistance and inductance of the cable, when it comes out the other end, the corners are rounded off, some noise is added, etc. At a certain length the signal is so bad your phase locked loop won't lock and the link fails.
There may be active extenders that can increase the distance you can achieve but the best solution is to get a short cable and move them closer.
Hi Walter...
I have no issue spending money where it serves me a purpose...just hate to chase leads that don't fix the problem
