Quark testing 8th Aug
- Been thanked: 8791 times
Finally after a mountain of images to plough through I have compiled all my Quark testing images together.
I have wanted to do this since I bought the Quark but having the time in the Sun to do this test was a million to one chance. Considering this year I have not had more than a 30 minute run of blue sky the chances of getting 2 hrs was slim. However, Saturday I had 4 hours of pure blue before it clouded up and so was able to do this test.
I set the Quark on zero point which is 12 o'clock on the dial (middle) and bagged some images of the AR and filament and prominence, although like previously I really struggled with the prom exposure. I then started turning the dial clockwise to +01 and waited for the green light to come on. Now I knew this position was better (more on band) the last time I had used it but this is all I had managed. I then kept imaging the same 3 objects on the same exposure (no flats) for every point on the dial clockwise to +05. I then turned the dial all the way back to -05 counterclockwise and took the same images again each click until I got back to centre point again. So here are the results, I think the best overall contrast, flatness of field, and prom exposure was +04 clockwise. You can see that 'on band' comes in from the bottom right, passes through the middle then leaves top left, just like a tilt tuned etalon, this surprised me, somehow I expected it to be like a pressure tuner with an even field. Now I know why I had been struggling with the prominence on the first two outings. I think it is very important for each Quark user to try this out at some point if they can, especially if you have a problem with uneven field or struggling to see prominences. If you spend a lot of money it is worth getting to know the beast you bought
2015-08-08 AR12396 by Alexandra Hart, on Flickr
2015-08-08 Prominence by Alexandra Hart, on Flickr
2015-08-08 Filament by Alexandra Hart, on Flickr
Then some fun in the blue wing, well I had the images anyway
Spicule 'twinning' only observed in the blue wing
080815_100547 -05 crop by Alexandra Hart, on Flickr
Bright Arch filament footpoints - not to be confused with Ellerman bombs!
080815_100829 -05 Bright footpoints by Alexandra Hart, on Flickr
Ellerman bombs (only distinguished from footpoints if you take a series of images)
2015-08-08 Ellerman bombs by Alexandra Hart, on Flickr
A prominence showing the blue shifted parts and blue shifted spicules.
080815_095413 +05 & -05 Blue shift combo by Alexandra Hart, on Flickr
I had more fun doing this than I expected, I hope you enjoy them
and a couple of snaps with the 2 PSTs and the DMK41 on 10th August
2015-08-10 18-48-24 f colour by Alexandra Hart, on Flickr
2015-08-10 19-03-20 f colour by Alexandra Hart, on Flickr
Thanks for wading through them all.
- sulcis2000
- Has thanked: 2 times
- Been thanked: 477 times
Re: Quark testing 8th Aug
Very interesting test!!
Ale
Ale
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- Been thanked: 1735 times
Thanks for this, Alexandra. This was a lot of work.
Waiting for the Quark to get back on band after each dial click is one of my pet peeves, especially since imaging time can be scarce. I've been using the "0" position because it gives me workable images but now you've "guilted" me into trying what you've done, at least visually.
Lou
Lou
Thanks for sharing and for great work, Alexandra.
That's what i must do with my new Quark.
What telescope did you use while testing and did you use focal reducer?
Aleksey
Lunt LS100THa, Coronado SolarMax II 90 Filter + BF 15 on WO Megrez 90, PST + SW 1025 mod, Quark + SW150/750 in test mode
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Yes indeed, very informative. Thanks for doing this. Now all
I need is 4 hrs blue skies :-)
David
David
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Amazing test Alexandra, thanks. +04/05 for disk features and proms, seems the way to go with your Quark
I will keep it as a reference. Maybe I will buy a Quark soon.
best regards
best regards
Pedro Re'
Thanks guys! if you own a Quark, really this is an essential test to get the most of your equipment. I thought it was great at +01 but was having trouble with proms, now I know that +04 is 100% better and proms were easy.
The scope used was a 140mm f7 refractor stopped down to 135mm with a D-ERF, no focal reducer used and no flats.
Alexandra, I think you've got a very good Quark. When i put my Quark into 120ED F7.5 i see NR.
Aleksey
- Has thanked: 13 times
- Been thanked: 41 times
I don't think your Quark is at fault but a tilt adjuster maybe your best bet to get the most & avoid NR's.Rybak wrote:Alexandra, I think you've got a very good Quark. When i put my Quark into 120ED F7.5 i see NR.
As already voiced Alexandra a very good test, exactly what I did when I bought mine then suggested on various forums.Montana wrote:Thanks guys! if you own a Quark, really this is an essential test to get the most of your equipment. I thought it was great at +01 but was having trouble with proms, now I know that +04 is 100% better and proms were easy.
Glad you can grab your proms now though, I will be interested in your Quark / Solarscope Prom shoot out if you ever did one
Will ambient temp change the time it takes the tuner to settle after an adjustment ?
I see a lot of people saying it takes 10 minutes, mine seems to take a lot less to go green, curious that's all.
The Quark is a little gem in my book, without it I probably would not have even thought about getting into solar work.
Clear skies for the weekend would be nice but not looking good at the mo.
- Been thanked: 171 times
A great review Alexandra I suggest you email it to Daystar so there users don,t get frustrated.The off banding is almost identical to my old tilt tuned mechanism that I replaced with the Quark.Price wise these Quarks are excellent but for speed of setup the pressure tuned Lunts are the go.Single stack of courseHope you have Sun this weekend,
Really informative Alexandra. Great you got some clear skies. I am still waiting here in Montreal!
-Charles
-Charles
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Alexandra,
Thanks for sharing your test on the Quark. Overall how does its performance compare with your SF100 DS?
Alfred
Alfred
- Bill Edelen
Fantastic presentation, especially with the blue wing. Very nice.
Tyson- my amateur photography https://www.flickr.com/photos/134930728@N02/
Lunt LS50THa
Meade 10" F10 ACF
Skywatcher AZ-EQ6 GT
ASI224MC
Orion Skyview Pro
Lunt LS50THa
Meade 10" F10 ACF
ASI224MC
Orion Skyview Pro
- Has thanked: 20438 times
- Been thanked: 10245 times
A fine selection of images there!
- Has thanked: 6181 times
- Been thanked: 7142 times
Very interesting and informative test! Thanks a lot Alexandra!
Arne
Arne
