First time imaging for two months and I captured this nice little flare that fired up for about 3 or 4 minutes yesterday afternoon, Sunday 1st Nov.
Captured using Daystar Quark, very basic "el cheapo" 102 mm f6.5 Nova brand Achromat on Celestron AVX mount with a GSO reducer and ZWO ASI174MM CMOS camera.
I captured a sequence of 10 second SER video files using Firecapture'sn "autorun" feature, one video every 30 seconds, stacked the best 10% of frames in each video into a single frame using Autostakkert 2, then built those tiff frames into a timelapse video using DVS (Dave's Video Stabiliser). I then tinted and adjusted levels of the final video using Virtualdub and saved as an animated gif.
I saw an aircraft transit the disk too, but sadly didn't have the camera running when that happened.
Cheers,
Chris Morriss
New Zealand
Solar Flare timelapse animated gif. Quark
- c8er
- Has thanked: 4 times
- Been thanked: 9 times
Solar Ha setup: Daystar Ha Quark, APM 140/980 refractor, Coronado SMII 60 DS BF15, McDougall Solar AutoGuider. Skywatcher ST80, Orion ED 80, WO ZS66 SD, and Nova 102mm f/6.5 achromat refractors.
Other scopes: C8,C11, ES Comet Hunter Mak-Newt, on 10Micron GM1000HPS, Celestron AVX, 8SE, CG-5 and Skywatcher Solarquest mounts.
Cameras: Celestron Neximage Burst Mono, ZWO ASI294MC Pro, AS120MC, ASI174MM, ASI290MC, Canon 60D, Celestron Nightscape CCD
- Has thanked: 20813 times
- Been thanked: 10485 times
Re: Solar Flare timelapse animated gif. Quark
That's a great capture Chris!
- Has thanked: 8558 times
- Been thanked: 8290 times
Nice capture of flare and plasma plume ejection, Chris.
- c8er
Thanks Mark, Stu. I only saw the plasma plume after I processed it all, as that wasn't apparent when capturing the flare. Seeing wasn't great so the live view was pretty wobbly, and there were a few very thin hazy cloud patches coming across the fov during the captures, hence the very variable brightness during the timelapse.
I've got some still images to process yet from some earlier captures before lunch, during which I noticed some fast moving action crackling away in and around that sunspot complex, which got me organised to be ready to capture for timelapse if a flare fired up, which it duly did. The ASI174MM seems to be working well with the Quark now that I have found some useable gain/gamma settings, but I still haven't got a reducer spaced correctly to get decent reduction without vignetting in the corners of the biggish sensor fov.
Cheers,
Chris M
Cheers,
Chris M
- c8er
Thanks Alexandra.
- michael.h.f.wilkinson
great catch!
Solar kit: GP-C8 with Thousand Oaks Solar filter, APM 80mm F/6, Lunt Herschel Wedge, Solar Spectrum 0.3Å H-alpha filter, Beloptic Tri-Band ERF (80mm free aperture), Thousand Oaks 90mm ERF, Coronado SolarMax II 60mm with Double Stack Unit. Lunt straight B1800 Ca-K module.
What an event. Thanks for sharing that!
Tyson- my amateur photography https://www.flickr.com/photos/134930728@N02/
Lunt LS50THa
Meade 10" F10 ACF
Skywatcher AZ-EQ6 GT
ASI224MC
Orion Skyview Pro
Lunt LS50THa
Meade 10" F10 ACF
ASI224MC
Orion Skyview Pro
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
