SUN (20120513) again through a gap in the clouds
SUN (20120513) again through a gap in the clouds (bad seeing 1.5/5). I'm surprised how well it turned out (HR WL images of AR11476).
http://re.apaaweb.com/sun_20120513_LUNT152_WLX2-01.jpg
SUN (20120513) AR11746. LUNT 152 F/6, 2" Lunt Solar Wedge, X2 (1.7X) Barlow, Baader Solar Continuum filter, DMK41
http://re.apaaweb.com/sun_20120513_LUNT ... mosaic.jpg
SUN (20120513). LUNT 152 F/6, 2" Lunt Solar Wedge, Baader Solar Continuum filter, DMK41, two-panel mosaic
processed with Avistack/Autostakkert2 (HR WL) + Registax 6 + PS CS5
best
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: SUN (20120513) again through a gap in the clouds
Good catch Pedro!
Thanks guys. I had to fight the clouds and seeing was very bad. The end result is not bad... Image processing can do wonders
best
best
- Been thanked: 4340 times
Nicely done Pedro...very sharp.
True masterpieces. Pedro! It is so fun and informative to watch that spot change before our eyes. To me, it now appears to be shrinking. The glory days are coming to an end...
Chris Schur
Hi Pedro
very fine shots
very fine shots
Thanks again guys. AR11476 is surely shrinking. Check out this animated gif (same scale).
SUN (20120509/13) AR11476. LUNT 152 F/6, 2" Lunt Solar Wedge, X2 (1.7X) Barlow, Baader Solar Continuum filter, DMK41
best
