help needed with Lunt 60mm PT DS im new to this
astro1949
Oh, I get it now!
Oh, I get it now!
Been thanked: 8 times
Post by astro1949 » Wed Jul 13, 2016 2:19 pm
when i use my lunt 60 PT SS the sun "POPS" with detail !
when i DS with the 50mm TT i see very little detail (?)
the image is very dim -- its very hard to focus -- only 3/4 of the full disk is in-focus around the edge.
i try to use a Celstron Neximage 5MP camera -- problem is exposure time.
ss i can get about 100 times faster than DS.....
any suggestions
i have been using telescopes since 1960 ( Criterion 6" f/8---still have it!)
i have a meade 14" lx200 GPS SV-80 and SV - 102 so I am baffled that i can not tune and focus the Lunt........
thanks,
bob
upsate NY
Bob
Lunt 60 PT DS Meade 14" LX200 GPS SV 80mm F/7 SV 102MM F/11 ETX 125 10" F/5.5 Newt.
Celestron 5MP Orion 6MP V2 ZWO 174CC 178C 224C
rxdeath
Re: help needed with Lunt 60mm PT DS im new to this
Post by rxdeath » Wed Jul 13, 2016 8:34 pm
well ds will certainly be dimmer than ss, that is normal and expected, but it shouldn't be enough darker that it's a problem.
i'll skip asking all the questions since you sound experienced and maybe just recommend you post some pictures of the views, probably not me, but some on here can see a picture and tell what's up with your scope better than from a description.
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Wed Jul 13, 2016 10:21 pm
thanks, i am trying to get decent pics of ss vs ds but the clouds have been an issue every time i have the time to try it. I know a Picture is worth 1000 words.
just wondered if someone had come across this and it was a simple operator error.
i have been in contact with Lunt-- they sent me the "Blue" filter in the diaganol that is ( for some ) an issue ---mine was fine and it didnt help-- picture and exposure times will be comming next
Bob
rxdeath
Post by rxdeath » Wed Jul 13, 2016 11:13 pm
yea, ds took me a while to sort out, but there's only 2 things so its not too hard to go through all the options 1/4 or 1/2 turn at a time. i definitely experienced some 'red ball' issues where i got no detail because of the current tuning, but fiddling got rid of it, and i never had focus issues with 1 vs the other, at least not more than normal. the distance between the 'front' and 'side' of the sun is ~610,000 miles (430,000 (sun radius) * sqrt2 (45/45/90 triangle ratio is x/x/sqrt2x) ) i don't think that it is treated as infinity point source, so the rays from the edge do not reach the scope at the same time the rays from the front do. i think this is why with bigger scopes the mosaic is king vs full disc because each panel can be focused, smaller aperture doesn't seem to show this problem as much.
experts please correct me if i'm off base here, it's likely much more complex.
i would ask your altitude because at high alt you sometimes just can't get enough air into the PT, but you say single stack looks great so i don't think that's the issue.
if i had to guess i would say it's most likely something in the tilt tuned ds module, we had another individual on here who was getting horrible bandpass for some reason with a coronado setup....if it works solid in ss mode, then i would start pointing fingers at the ds50 end.
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Thu Jul 14, 2016 12:09 am
sun ds0006 11-34-31.tiff
sun0029 11-04-33.tiff
sun0001 11-00-21.tiff
first is DS next two are single stack images
Bob
rxdeath
Post by rxdeath » Thu Jul 14, 2016 1:39 am
trying to help with picture upload, not sure if the site is having problems:
ss:
ds:
ds:
rxdeath
Post by rxdeath » Thu Jul 14, 2016 1:47 am
i'm wondering if the camera has the dynamic range needed to be good for solar imaging, but idk.
ds looks like crap
ss looks better, but not quite right
hopefully one of the gurus chime in, maybe let us know if this is a brand new setup or did you get it second hand, etc...
Has thanked: 2036 times
Been thanked: 707 times
Post by Montana » Thu Jul 14, 2016 7:33 am
Mmmm don't upload Tif images, no one can view them, thanks rxdeath for the images :) The single stack looks OK, just need to remove the dust bunny and put the sun in the lower left corner to get a more even coverage.
I presume that you just screwed the double stack straight on following the first image and the view was like this? If that was the case something is seriously wrong with the double stack unit. The focus should be unchanged, the tuning might not be right but the focus is always the same. I would explain this to Lunt and show them the images as soon as possible as it is possible the etalon is decontacted and needs repair. The single stack unit looks fine.
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Thu Jul 14, 2016 10:48 am
thanks,
i have sent these and others to Lunt.
i will press them to help me now that we know the blue filter ( taht had some issues in other scopes) was not an issue with my scope.
bob
Bob
Marcello
Post by Marcello » Thu Jul 14, 2016 11:04 am
Hi Bob,
I have hours of experience with my Lunt 60 and the 50mm DS unit (that's the scope I used most in life indeed!) and I can only confirm you the words from Alexandra: adding the DS never affected focus. Exposure times yes of course, but never focus.
Hope you can solve the problem and enjoy that wonderful tool!
cheers
Marcello
Play in the sunshine, we're gonna get over !!
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Thu Jul 14, 2016 2:32 pm
thank You !
i'M excited to see what a functioning DS can do
bob
Bob
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Thu Jul 14, 2016 5:53 pm
thanks for all the Help---
just so you all know i can focus a telescope -this is a shot of Jupiter at 16:06 in full sun
telescope is 102mm SV Planet killer Celstron Nextimage 5mp
i'll be very happy when Lunt gets back to me.
jupiter 406P II.jpg (29.53 KiB) Viewed 3081 times
Bob
GUS
Has thanked: 1 time
Been thanked: 2 times
Post by GUS » Thu Jul 14, 2016 9:51 pm
Are you actually focusing on the sun or one of the ghost images of it. The images you've shown look very similar to an image of a ghost, and probably explains the focusing issue.
rxdeath
Post by rxdeath » Thu Jul 14, 2016 11:02 pm
ha, i mentioned the annoyance of ghosts with the tilt ds in our pms, but i never thought that could be the problem. from what i've seen here and experienced, lunt equipment is rarely just bunk and this being the problem would correspond to life in general: you make most of your own problems :)
my ghosts were (if the real sun image is in the center of a clock) in the direction of 2 and 8, the middle one is the real deal i'm pretty sure, i don't have it anymore so i can't check, but it will be obvious if you see all 3 which one is real. you should be able just to slew a little bit, another tell tale sign is that when you adjust the tilt tuner, the image will move. the 'real' sun will not move, ghosts will.
i don't see too many day shots of jupiter, looks pretty sharp considering i complain about a quarter moon ruining my photos...
**edit if you just screwed on the ds without moving anything as alexandra said, i'm pretty sure you would be on the 'real' sun, no ghosts in ss. if that's the case, i'd ship that puppy off to lunt. **
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Thu Jul 14, 2016 11:35 pm
i thought of Ghost --- when i tilt, the reflex images move across the field of view.
i turn the wheel about 3 or 4 1/8 turns ( or so) and the ghost are gone
i did try on of the others, but i had to slew the scope quite a bit from SS mode---just checking the dumb stuff
my operation the last few tries is to start SS -- focus--tune --screw DS on --
saga continues ====lunt got back to me 5 minutes ago ---they are sitting down tomorrow and going over all my info and pictures ( 15 or 20 i sent in since we started talking) and we will go from there.
i'm a Physicist,so i tend to over saturate with data, pics, and details....even if i have no idea what i'm doing !
this group is GREAT.....
bob
Bob
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Sun Jul 17, 2016 10:39 pm
tried again today Single stack - tune/focus --CAREFULLY added DS --
i also found if i rotate the DS unit -- the smeared image rotates....
these were taken with a Meade DSI III mono....
comments ?
DS sun 1038AM.jpg (31.58 KiB) Viewed 3045 times
SS sun 1032AM.jpg (79.58 KiB) Viewed 3045 times
DS sun 1036AM.jpg (31.06 KiB) Viewed 3045 times
SS Sun 1041AM.jpg (44.43 KiB) Viewed 3045 times
Bob
[whrudey]
Post by [whrudey] » Mon Jul 18, 2016 2:03 am
Hi Astro1949;
Some years ago before we could afford better imagers, I used the NextImage5 and, seldom obtained passable images. Have you considered using a different imaging device ? The ZWO series are very good and offer enough variety to meet all needs. Our NextImage5 is now in its box at the bottom of a drawer.
Just a thought ..
Bill
Has thanked: 800 times
Been thanked: 697 times
Post by Carbon60 » Mon Jul 18, 2016 5:48 am
I use a DS Lunt60 and what you describe definitely is not 'normal'. Setting up in SS mode and then adding the DS etalon does not change anything other than tuning (and brightness, of course), so I'm baffled as to what's going on in your case. You would know if it's a ghost image, or not, for sure when re-tuning the front etalon.
I hope Lunt can offer a solution.
Good luck.
pedro
Has thanked: 3 times
Been thanked: 681 times
Post by pedro » Mon Jul 18, 2016 10:46 am
I would recommend using your scope without a second etalon first. My experience with DS is not great, I can always get better results with a single etalon. That said check out two FD images obtained about 2 years ago
LUNT60 + CORONADO SM60.
The single stack image looks better to me (and brighter)
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Mon Jul 18, 2016 10:56 am
thanks Bill, stu and Pedro ---
hopefully LUNT will get back to me today -- i have been working with then for about 1 month...
bob
Bob
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Wed Jul 20, 2016 2:38 pm
My LS50F will arrive at Lunt thursday.
they think the Etalon is Decontacted....
im sure all will end well and I'll be using DS soon with success
thanks for all the posts and help.
Bob
rxdeath
Post by rxdeath » Thu Jul 21, 2016 2:26 am
they will sort you out as quickly as possible i'm sure. you'll be soooo happy when you get it back i still remember my first ds image, it looked like the sun needed a lint roller because of the additional detail, proms are so much darker :)
ps
pedro, that is the best detail and contrast i've ever seen a singlestack image have. i would have bet money it was a ds. do you have a capture file you'd be able to share with us for this great image?
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Fri Aug 12, 2016 1:43 pm
My DS filter was decontacted--must have happend in shipping to OPT or opt-to-me.........
i hope to get it next week. i'll try it asap and report.
Bob
Post by Montana » Fri Aug 12, 2016 2:13 pm
That's great news that the problem has been identified, it means you are well on the way to fixing it :)
astro1949
Oh, I get it now!
Oh, I get it now!
Post by astro1949 » Fri Aug 12, 2016 8:18 pm
so now I need a new CAMERA !!
ZWO (?)
Bob
