FC plugin for DIY Solar Scintillation Seeing Monitor
RTJoe
Been thanked: 1 time
Post by RTJoe »
Hello,
meanwhile I have developed a plugin for the new plugin interface of FireCapture. The plugin requires the DIY Seeing Monitor described in this topic: viewtopic.php?t=16746.
This plugin provides the following functionality inside the FireCapture software:
  • SSSMon measures the current seeing
  • Recording is started if seeing reaches configured minimum quality
  • Recording is paused as long as seeing is worse than configured value
  • Recording is stopped after configured time
  • After recording is stopped and after a configured pause time, a new recording run can be started automatically
  • The maximum number of recording runs is configurable
Screenshot of an example setup:
With this setup, the recording is started as soon as seeing is 2.0 or less (smaller value means better seeing). The recording is stopped after 45 seconds. As long as the seeing is worse than 2.5, the recording is paused. After a recording finished, there is a (minimum) delay of 5 minutes (300 seconds) until the next recording might start (if the seeing is better than 2.5 again). A maximum of 10 recoding runs is executed.
Start this setup, have some cold beverage and let the plugin hunt the moments of good seeing.
You can find the plugin for download and additional information on my website: http://www.joachim-stehle.de/sssm_eng.html. Have a look into the documentation for a detailed description how to install and use the plugin.
Feel free to download the software and report your comments.
Joachim
Has thanked: 156 times
Been thanked: 893 times
Re: FC plugin for DIY Solar Scintillation Seeing Monitor
Post by Valery »
Hi Joachim,
Thanks a lot for your works making a SSM affordable and suited for a FC software.
BTW. PM sent.
Post by Valery »
Hi Joachim,
One more very useful option for this SSM software.
The software should calculate best seeing value and averaged seeing value - for better and faster choice of the movies which are
suitable for further processing. I usually spend a lot of time trying to choose best movies among all recorded during given session.
This is quite annoying and boring procedure. This is the reason I public my results too late or do not publish them at all.
Do you think this is possible to include such a option?
RTJoe
Post by RTJoe »
Hello Valery,
thank you for your comments. Average and best seeing calculation should be no problem.
I will evaluate the possibilities how to use the values. It’s easy to display the values and to create a special log file for the plugin. It would be more convenient if the measures could be logged into the FC log file or appended to the name of the captured file. But this would require Torsten to extend the FC plugin interface.
Joachim
Post by Valery »
This will be the best option.
Has thanked: 20757 times
Been thanked: 10444 times
Interesting! Thanks!
Will this work with the Airylab SSM?
RTJoe
Post by RTJoe »
the plugin currently supports a “DIY” protocol for communication with the DIY SSSMon only.
I guess it would be easy to extend the FireCapture plugin for the Airylab SSM, because it’s also Arduino based and I assume it also uses a serial protocol on USB. But I don’t know whether Airylab wants to disclose their protocol. Maybe I just ask at Airylab for information.
Joachim
RTJoe
Post by RTJoe »
Many thanks to AiryLab - they have already send me information about the protocol!
I will add support for the SSM into the FireCapture plugin soon. Would somebody who already owns an AiryLab SSM please volunteer to test the software? I have the DIY device only.
Joachim
robert
Has thanked: 4 times
Been thanked: 1275 times
Post by robert »
Well done. Very interesting stuff!
Robert
Hi, coming back to this thread. Is the Airylab SSM supported in Firecapture now?
robert
Post by robert »
Yes
I've got the plugin installed, will have a go to get things fired up in the morning.
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
Where is the Airylab SSM plugin Mark?
pedro
Post by pedro »
Been thanked: 4959 times
Post by eroel »
Joachim:
A very interesting thread.
Thanks for sharing,
robert
Post by robert »
Interesting flare detection plug in as well. I just noticed
http://www.joachim-stehle.de/flaredetect_eng.html
I'm playing with the SSM plugin at the moment, I like it a lot!
