Sol from the 21st of January 2017.
eroel
Been thanked: 4959 times
Post by eroel »
Hello:
Beautiful and cold day for us (1°C). The jetstream is terrible, I had a hard time trying to focus with such a jumpy seeing. I am at the rural observatory and used the 6" f/12 AP refractor with a 2X Baader telecentric and an old Daystar ATM.
Here is the best I could do.
Took some FD´s with a 76mm TeleVue fitted with old Coronado 40mm etalons, can not show them yet, because I don´t have all the software I use to process my images.
Happy and sunny weekend to all.
Sol del 21 de enero del 2017-Daystar-3an.jpg (1.25 MiB) Viewed 1441 times
Derek Klepp
Been thanked: 171 times
Re: Sol from the 21st of January 2017.
Post by Derek Klepp »
Thanks Eric a cool day for you.
Albuqshutterbug
Been thanked: 26 times
Post by Albuqshutterbug »
Eric, you did much better than I did. Very nice detail,
I should have been so fortunate.
I am on the other edge of stream and was being bounced around with pretty strong wind as well.
Well done.
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Very nice detailed image, Eric.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Your image is excellent despite the conditions, nice work :bow
For a change it is milder here this weekend...+5C with fog and light drizzle the past few days. The snow is slowly thinning out, but I hope it hold on until it turns cold again later in the week.
Has thanked: 20757 times
Been thanked: 10444 times
Nice capture Eric! Ahh, the joys of the jet stream...
Has thanked: 17925 times
Been thanked: 8894 times
Still a superb capture :hamster: :bow
trice001
Post by trice001 »
PCs perform better with customary upkeep of the registry. The registry holds data about the PCs settings and arrangements. The working framework utilizes the registry to screen the connections of the working framework, equipment, and programming. The PC registry keeps record of the exercises in the PC and after some time the sections increment. This is the motivation behind why PCs typically back off following a while of utilization. At the point when the registry winds up noticeably stacked and jumbled with records, the execution of PC debases. For this situation, the best programming to accelerate PC is the registry more clean. There are numerous registry cleaning programming that can be downloaded from the Internet. A standout amongst the most generally utilized registry cleaner is the CCleaner. It can be downloaded for nothing and it is the best programming to accelerate PC. Beside cleaning the registry, it gets out impermanent Internet documents and wipe out repetitive records. Not at all like other registry cleaners, CCleaner is perceived as substantially less forceful which makes it reasonable for a normal client. A registry cleaner programming speeds up PC by checking the registry and evacuating repetitive records. It can likewise analyze and repair registry blunders and issues that reason the PC to back off.
Thanks& regards,
Angel anave
Toronto Web Development | Web Development Toronto
