Quark selection not very good seeing sorry
- Has thanked: 13 times
- Been thanked: 41 times
Finally salvaged what I could from almost 1Tb of data in total.
Some better than others & like most people wishing for better seeing to come.
Thought I would try some processing left field, not everyone's taste but feedback appreciated.
Thanks for looking.
Thanks for looking.
- Albuqshutterbug
- Been thanked: 26 times
Re: Quark selection not very good seeing sorry
Those first 3 shots are outrageously great!
Wow the detail and even flow is gorgeous.
I love all the shots but those first three make me droll.
Well done.
Well done.
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
For Imaging:
- The Sun?
Those first 3 really are works of art - amazing
Steve
Technosky 152 with 135mm D-ERF + Quark
PST Evostar & Tal 100 mod with 100mm D-ERF
SM60II SM40 +Ickharus 102 + 10mm BF
Lunt 50 DS PG Grasshopper 3
White Light stuff - not yet used...
- Been thanked: 10489 times
Cool pics Ewan!
Nicely done. I like the interpretation of your data by your processing that focuses on the plasma "flows". Repeated use of sharpening then smoothing filters delivers a nice liquid like feel. Like you say not to all people tastes but just another interesting way to look at the data.
Ted
Ted
- Has thanked: 9326 times
- Been thanked: 6158 times
That is a truly amazing set, Ewan. The plasma lines in the first three images are incredibly smooth. Well done.
I like image #9 from 08 04 2017. Good real details.
- Has thanked: 8559 times
- Been thanked: 8291 times
More art than science, but beautiful nevertheless. No harm in experimenting and offering something a bit different.
I bet the first two look stunning coloured.
- Been thanked: 171 times
I am probably pushing the limit of the 152mm Valery I know that. Seeing in some were very fortunate & lucky. Tried a lot of different capture settings & found some good ones. I also extended the dew shield with the D-ERF on it, not sure if that made a difference than being closed though, any thoughts ?
Thank you for the kind comments. I did say not everyone's taste but trying different things is in my nature. I shall give the 1st 3 some colour as suggested & see if it will go on a wall somewhere.
Atb
Atb
I nearly fell off my chair in shock, the first 2 images are to die for, I love it : they are like smooth velvety liquid chocolate....mmmmm
Thanks Alexandra, with so few & far between opportunities for solar work at the mo I was bored so tried something else, makes for a change I guess. Hope your capturing plenty your end.
Atb
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Nice shots Ewan
Can you tell us more on your image processing flow
Pedro Re'
- Been thanked: 1735 times
Hi, Ewan
I had to add my admiration for your work here. The first 3 are stunning and whatever your technique involves, you should continue with it.
The detail in the more "standard" looking images is outstanding.
Lou
Lou
I'm guessing you're actually running at 125mm here, measure the free diameter of the ERF. Its a 135mm DERF and some of it has to be held within the perimeter of the cell.Ewan wrote: ↑Wed Apr 12, 2017 8:30 am I am probably pushing the limit of the 152mm Valery I know that. Seeing in some were very fortunate & lucky. Tried a lot of different capture settings & found some good ones. I also extended the dew shield with the D-ERF on it, not sure if that made a difference than being closed though, any thoughts ?
It's using 135mm which puts me around F28 ish I think. Was wondering what difference, if any, having the dew shield up / down made apart from maybe scope balance.marktownley wrote: ↑Wed Apr 12, 2017 5:05 pmI'm guessing you're actually running at 125mm here, measure the free diameter of the ERF. Its a 135mm DERF and some of it has to be held within the perimeter of the cell.Ewan wrote: ↑Wed Apr 12, 2017 8:30 am I am probably pushing the limit of the 152mm Valery I know that. Seeing in some were very fortunate & lucky. Tried a lot of different capture settings & found some good ones. I also extended the dew shield with the D-ERF on it, not sure if that made a difference than being closed though, any thoughts ?
It will make no difference at all the position of the dew shield.Ewan wrote: ↑Wed Apr 12, 2017 5:53 pmIt's using 135mm which puts me around F28 ish I think. Was wondering what difference, if any, having the dew shield up / down made apart from maybe scope balance.marktownley wrote: ↑Wed Apr 12, 2017 5:05 pmI'm guessing you're actually running at 125mm here, measure the free diameter of the ERF. Its a 135mm DERF and some of it has to be held within the perimeter of the cell.Ewan wrote: ↑Wed Apr 12, 2017 8:30 am I am probably pushing the limit of the 152mm Valery I know that. Seeing in some were very fortunate & lucky. Tried a lot of different capture settings & found some good ones. I also extended the dew shield with the D-ERF on it, not sure if that made a difference than being closed though, any thoughts ?
It's a Marmite moment some love it some hate it, but I just keep having to come back for another look
- Been thanked: 4980 times
Ewan:
Very good images, specially #9.
