15Apr 17 (Singapore) - SF100 single etalon on a 152mm refractor
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Setup 1 for Full Disk: SF50 double stacked etalons on a Borg 76mm refractor + PGR Scorpion camera.
Setup 2 for HD H-Alpha: Solarscope SF100 single etalon on a Celestron C6R 152mm refractor + Televue x3 barlow + ASI174mm camera.
First the Fill disk
420 frames selected from 4000 frames
Pseudo colour added in good measure
First the Fill disk
- Been thanked: 10248 times
Re: 15Apr 17 (Singapore) - SF100 single etalon on a 152mm refractor
Very nice images and very nice equipment Alfred!
- Has thanked: 9145 times
- Been thanked: 6026 times
Great images, Alfred ! I particularly like the second one of surface detail. Excellent processing.
- Been thanked: 8793 times
Beautiful images!!!
Happy Easter
Happy Easter
- yltansg
Hi Alexandra,
Thanks for your kind comments and wishing you and all a great Easter too!
Alfred
- yltansg
Hi Franco,
The Sun was covered with a thin layer of clouds that just wouldn't go away. I could only achieve an average of 45 frames per second with a shutter of 21ms. Gain was set rather high at 201. Hence the frames were rather noisy and I compensated that by using 420 frames to increase the SNR. I would like to see the image quality with better seeing.
Alfred.
- yltansg
Hi Mark,
Thanks for your kind comment. I have the C6R refractor and SF100 etalons for some time now but have not used them as I had given more attention to the ARIES D-ERFs. I am making an adapter to use a PST Stage 2 mod on a ARIES 8" D-ERF + 8" SCT. I hope to do some more imaging with the SF100 before HA imaging on the C8 + ARIES D-ERF.
Alfred
- Been thanked: 4904 times
Alfred:
Beautiful FD and super HR image with the 152mm refractor.
Best regards, hope to also soon will start using my new 265mm Aries ERF.
Have a nice Sunday,
Have a nice Sunday,
- yltansg
Thanks Eric for your kind comments.
What H-Alpha etalon are you using with the C9.25 SCT + 265mm ARIES D-ERF?
Alfred
Alfred:
I will use the 265mm ERF for my 10" f/20 TEC Maksutov, and probably also for my 12" f/10 Meade SCT.
As for the etalons, I can use an 0.45A° ATM Daystar, and a 0.5A° modified Daystar T scanner now in a new housing with an internal oven and with a tilt provision.
Both scopes have beautifully corrected optics, the 12" f/10 SCT was hand picked many years ago from dozens of units, each one optically checked.
- Has thanked: 8418 times
- Been thanked: 8165 times
Lovely images, Alfred. The second one is particularly good. Nice kit.
- Been thanked: 171 times
A good Easter collection Alfred.
- yltansg
Hi Stu,
Thanks for your compliments. The second one was made with 420 frames. I did another one with 600 frames.
I can't really tell if there is any improvement in terms of Signal-to-Noise ratio.
Alfred
- yltansg
