Coronagraph and Solarscope
- Been thanked: 8907 times
My first sunshine for a month at weekend, so I was up early and was set up by 8.30am (earliest I can go in my garden). I really wanted to test the newly refurbished Coronagraph but I knew I didn't have much time before clouds were due in. I originally started out using the wedge Wolfgang gave me but I couldn't find focus anywhere with the Grasshopper either occulting disc or solar disc, I didn't have time to waste so I switched back to the configuration I had found before and first found focus of the occulting disc, then put the exposure to the lowest the Grasshopper would go and focused the solar disc like so
Coronagraph test by Alexandra Hart, on Flickr
I then moved the solar disc to just underneath the occulting disc and everything goes black. I then raised the exposure very bright and closed the iris to reduce the glare, like so
after an hour and a half of painfully trying to get round the solar disc I couldn't find any prominences at all
The haze had started to thicken and I had a lovely solar solar halo
2017-06-03 Solar halo by Alexandra Hart, on Flickr
and one with a Buzzard
2017-06-03 Solar halo & Buzzard by Alexandra Hart, on Flickr
I was quite disappointed, so I am not sure what I am doing wrong or were the prominences today too small? no idea really, I need to study the manual again.
I then swapped out to the Solarscope but it was getting near impossible to image by then and I only managed 2 frames and no flat.
2017-06-03 Northern hemisphere f colour by Alexandra Hart, on Flickr
2017-06-03 Northern hemisphere imp b by Alexandra Hart, on Flickr
Oh well, raining again now. I am hoping it might clear this evening again for round 2.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Re: Coronagraph and Solarscope
Hi Alexandra,
indeed very strange nothing shows up when the solarmax clearly shows shome prominences. Are you sure you did not get your exposure to bright and the prominences get lost in the glare. Focus looks ok, so that should not be the problem. (At least I think ...)
Lovely halo shots anyway.
- Has thanked: 1190 times
- Been thanked: 1386 times
- Has thanked: 8559 times
- Been thanked: 8297 times
I feel your pain, Alexandra. Nothing useful from me to add.
- Has thanked: 20828 times
- Been thanked: 10499 times
It's frustrating when it doesn't stay blue for long enough. I don't think I'd waste much time with the coronograph if i'm being honest with you, I think you'll get much better proms with the PST. It's interesting as a 'historical' instrument, but's its use for solar observing is crude compared to the alternatives. You will get best results with it when it is those 'deep blue' sky days with no haze etc, that will give best contrast and best chance of seeing proms. Maybe use a ND filter too on the camera if there is too much light.
Thanks guys, I won't let the coronagraph beat me, if Wolfgang can see proms through it then I should be able to as well.
In the evening the skies cleared apart from a few dotted clouds so I was able to have a much better attempt with the Solarscope.
For full detail click on the image then click on the image on Flickr for a magnified view
2017-06-03 Full disc by Alexandra Hart, on Flickr
2017-06-03 Full disc f colour by Alexandra Hart, on Flickr
030617_174729_ by Alexandra Hart, on Flickr
030617_174729_f colour by Alexandra Hart, on Flickr
030617_174815_ by Alexandra Hart, on Flickr
030617_174815_f colour by Alexandra Hart, on Flickr
030617_175212_ by Alexandra Hart, on Flickr
030617_175212_f colour by Alexandra Hart, on Flickr
Kind regards
Kind regards
Absolutely superb detail in these additions Alexandra.
- Been thanked: 4981 times
Alexandra:
Beautiful images with the Solarscope.
As for the Coronagraph, I think that you have to tilt the filter with the side lever, so to see the protuberances.
I did try the tilt Eric and it seemed to remove a reflection and that was about it
Anyway, here is an animation of AR12661 from 17:39-18:06 UTC
2017-06-04-animation-AR12661 by Alexandra Hart, on Flickr
That is the last by the way
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Super set of images and I love that last animation!
David
- Has thanked: 9327 times
- Been thanked: 6163 times
- Been thanked: 171 times
- GreatAttractor
- Has thanked: 748 times
- Been thanked: 757 times
Excellent pics, and the animation! I'd love it if you used even shorter intervals next time; your scope's aperture in this kind of seeing can't go to waste.
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Hi Alexandra,
I like the animation best and keep trying with the Conoragraph. All the best!
Alfred
Alfred
The animation is super!
- jp-brahic
- Has thanked: 45 times
- Been thanked: 131 times
very nice série Alexandra as usual!!! fine pics
JP
JP
TN 450mm F/D 4 Zerodur
- Been thanked: 6694 times
I agree with Mark, the coronograph is an historical instrument and you will get better results with your other solar scopes. It is interesting though, please keep us up to date with your experiments, I'm very interested.
Super images with the Solarscope
