Dear All,
Here are some additional images of AR 2659 taken with the 300 mm solar Newtonian and various filters.
May 26 with the 540 nm filter, there are some ombral dots :
May 27, with the 540 nm filter again, there are some faculae on the left on the sunspot group :
Same day with the 500 nm filter, the resolution increases as well as the contrast of faculae :
With the G band filter, the seeing gets worse, but the resolution gets really good in some parts of the image :
Farewell to the spot on May 29, with the 540 nm filter again:
The 500 nm (OIII) is a good all around filter for observation of the photosphere, still not well known.
AR 2659 on May 26,27 & 29 with the 300 Newtonian and various filters
- Been thanked: 2713 times
Re: AR 2659 on May 26,27 & 29 with the 300 Newtonian and various filters
Excellent series of images, Christian!
Very nice resolution! I am green envy for such a seeing quality .
Valery.
Valery.
- Been thanked: 171 times
Thanks Christian and good to know about the filters.
- Has thanked: 1171 times
- Been thanked: 1360 times
Super duper nice! Amazing detail!
- [whrudey]
HI Christian;
As usual, your images are outstanding. You continue to be the "gold standard" the rest of us aspire to.
Many thanks,
Bill
Many thanks,
Bill
- Been thanked: 4340 times
Outstanding resolution Christian
- Has thanked: 8415 times
- Been thanked: 8161 times
Wonderful images, Christian. Beautiful detail.
- Has thanked: 173 times
- Been thanked: 615 times
Christian,
I see Optolong have a reasonably priced OIII (25nm bandwidth) filter.
Any comment? Do you think there would be the same improvement as you found with the 10nm version?
