Getting In Closer - Saturday Sunshine 17th June
- Has thanked: 20834 times
- Been thanked: 10502 times
This weekend was forecast to be glorious, so I was up early on saturday to try and get the best of the seeing with temperatures getting up to 28c. Properly blue skies throughout the day meant I was able to image in a range of wavelengths and also at a range of scales.
First off the CaK, and the full disk with the 40mm scope @ 500mm fl with the homebrew CaK filter and the PGR CH3 camera.
cak-disk-bw by Mark Townley, on Flickr
cak-disk-colour by Mark Townley, on Flickr
Then, progressively zooming in on the interesting bits with the 100mm Tal refractor running at 80mm aperture (tri-band ERF).
ar12662-cak-80mm-bw by Mark Townley, on Flickr
ar12662-cak-80mm-colour by Mark Townley, on Flickr
ar12663-CaK-80mm-bw by Mark Townley, on Flickr
ar12663-CaK-80mm-colour by Mark Townley, on Flickr
ar12662-cak-80mm-close-bw by Mark Townley, on Flickr
ar12662-cak-80mm-close-colour by Mark Townley, on Flickr
ar12663-CaK-80mm-close-bw by Mark Townley, on Flickr
ar12663-CaK-80mm-close-colour by Mark Townley, on Flickr
plage-cak-bw by Mark Townley, on Flickr
plage-cak-colour by Mark Townley, on Flickr
In Ha, there was a range of things to be seen. First off with the 56mm scope, double stacked quark Baader solar telecompressor (0.7x) and CH3 with 2x2 binning.
ha-full-disk-bw by Mark Townley, on Flickr
ha-full-disk-colour by Mark Townley, on Flickr
Moving up a notch now to the 100mm Tal, same etalon / camera combination, somewhere around 3m focal length.
ar12662-100mm-bw by Mark Townley, on Flickr
ar12662-100mm-colour by Mark Townley, on Flickr
ar12663-100mm-bw by Mark Townley, on Flickr
ar12663-100mm-colour by Mark Townley, on Flickr
The seeing is always the limiter, but you have to try, now the 203mm Airylab HaT, same etalon / camera setup, focal length somewhere just over 6m.
ar12662-hat-red-bw by Mark Townley, on Flickr
ar12662-hat-red-colour by Mark Townley, on Flickr
Then, same again, but without the solar telecompressor, so focal length getting close to 9m.
ar12662-Hat-bw by Mark Townley, on Flickr
ar12662-Hat-colour by Mark Townley, on Flickr
ar12663-hat-bw by Mark Townley, on Flickr
ar12663-hat-colour by Mark Townley, on Flickr
Hope you like! Todays seeing was better first thing, so more to come later on.
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Re: Getting In Closer - Saturday Sunshine 17th June
Wow, fantastic set Mark. you weren't kidding about getting in close
David
Nice series of sun images, Mark!
The only info I was not able to find is what the etalons have you used for this session.
Thanks for sharing.
Thanks for sharing.
- Been thanked: 171 times
Definitely worth the try Mark and good to see you getting in a very comprehensive session.
Thanks guys!
It's my trusty Quark / PST etalon combo Valery. Using this, with 2x2 binning on the PGR CH3 and gain applied (camera powered by 12v battery for less noise) means I can run at about 3-4ms exposure time at ~9m focal length, throw in i've now managed to get the camera capturing at 120fps all adds up to easier imaging at these longer focal lengths.
- Has thanked: 9327 times
- Been thanked: 6163 times
A great and fruitful session, Mark !
It is nice to see in one run different frequencies and equipment producing different results and being able to compare in one scroll.
- Been thanked: 1735 times
Hi, Mark
I like the scale and especially the contrast in your images.
I'm assuming from the info in your reply to Valery that you are using the original Quark + PST etalon. Does it matter whether you sjip the Quark into the PST etalon or the other way around ? My PST adaptors (2") make it easy to mount the Quark onto the PST etalon but it's more difficult to reverse the 2 etalons. I've tried combining these 2 etalons but found the view too dark but I'll try again with 2x2 binning.
Thanks Franco, Hiya Lou, I've never tried the PST etalon before the Quark, mine sits after it. I was using the native 4.3x telecentric on the Quark here, rather than the HaT 2.79x telecentric.
- Has thanked: 8559 times
- Been thanked: 8297 times
A fabulous set of images, Mark. Glad you managed to make the most of the good weather.
Thanks Stu!
- Albuqshutterbug
- Been thanked: 26 times
Holy Cow those are great Mark.
Very well done.
Jim
Very well done.
Jim
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
For Imaging:
- Been thanked: 8907 times
Wow!! the mega closeups are out of this world !!
Superb CaK too, I wish I could process mine a bit better, yours always look fab
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Hi Mark
Thanks for this collection - you did fall into the Sun! So much to see there.
- Been thanked: 4981 times
Mark:
Beautiful clean session with different setups.
You made the most of the weather opportunity.
- Been thanked: 4434 times
An excellent session with superb results Mark...well done
