A Long Time Between Drinks
- Been thanked: 171 times
Finally some Ha(Lunt 100) and CaK(Lunt Wedge and 127mm) after several months.Had to remember how to process.Also some Sunrise pics.
- jul1710.jpg (156.58 KiB) Viewed 2140 times
- Collages431-002.jpg (192.32 KiB) Viewed 2140 times
- Collages431-003.jpg (189.15 KiB) Viewed 2140 times
- Collages431-004.jpg (103.49 KiB) Viewed 2140 times
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: A Long Time Between Drinks
Glad to see you back on the Ha imaging wagon Derek.
David
PS Is that fisherman just going home from the previous montage appearance ?
David
- Has thanked: 20437 times
- Been thanked: 10245 times
Nice shots, good to see you have the solar kit out again Derek!
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Great images there Derek, well done, glad you had your solar fix
Pedro Re'
Thanks yes David he,s just heading home.It was great to get some Ha .I forgot just how good the old Lunt 100 is.
- Has thanked: 9145 times
- Been thanked: 6025 times
- Been thanked: 4340 times
Hi Derek...
Great to see you're back to doing some hi-res solar work again.
The sunrise sequence is beautiful as are the collage...thanks for sharing.
- Been thanked: 8791 times
Wow, I think I will save the first image, that is gem lovely to see the close ups of the big spot too and great that you are imaging again
- Been thanked: 4904 times
- Been thanked: 16 times
Beautiful shots Derek and especially the nuclear sunrise!
Regards
Andy
Regards
Andy
- Been thanked: 1576 times
- turi lo vecchio
- Been thanked: 235 times
Thanks for the compliments it has gone back to clouds here again and showers.Probably due to the fact a got a knew wide angle camera lense.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Great to see some 'close up' images of the Sun from you Derek. Hopefully it will be clear on the weekend (my next available session).
