I used a new configuration of my LS80 here, one which allows use of its full 80mm, instead of it being baffled by a fronted mounted LS60F. To double stack the LS80, I attached a Quark Combo at the end of the scope. The camera used was an ASI178(1/2" sensor, 6Mp). The camera does have an issue in the form of a "fixed noise pattern", a grid of tiny squares in one region of the frame which don't always show up in live view but often do show up in sharpening. A 2.5X Powermate was used before the Combo.
The ROI used was 1900x1400 to cut the FNP and to improve the frame rate.
The next image is a 2 pane mosaic
Lou
AR and proms from July 11
- Been thanked: 1735 times
- Been thanked: 171 times
- Has thanked: 20438 times
- Been thanked: 10245 times
Re: AR and proms from July 11
Interesting configuration that looks to be giving you decent results Lou!
- Been thanked: 8791 times
