Thank you for the advise. I went back and redid this stack and processed it as an Inverse shot,
I used the 500 setting with prevent ringing turned on and viewed at 150%.
I think this is much better but may still be a bit over sharp.
Thoughts?
Thanks again,
Jim
Processing using the new 500 starting point After Advice
- Albuqshutterbug
- Been thanked: 26 times
- video0012 17-07-12 13-47-46_lapl6_ap318 impgg inverse.jpg (1 MiB) Viewed 1588 times
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
For Imaging:
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: Processing using the new 500 starting point After Advice
It's nice! Works well What's the normal like?
- Albuqshutterbug
I'm guessing you mean without sharpening, just stacked?
The second shot is stacked only and not even cropped.
Jim
Jim
- video0012 17-07-12 13-47-46_lapl6_ap318 impgg.jpg (963.31 KiB) Viewed 1567 times
- Unprocessed stack only.jpg (237.45 KiB) Viewed 1569 times
For Imaging:
For Imaging:
- Been thanked: 8793 times
I think Mark meant the positive version
Looking at the positive it is much improved from the first
Yes I did and yes it is!
When using AS make sure you have cropped mode on then you don't get the black jaggedy edges around the stacked image.
- Albuqshutterbug
Thank you both very much.
Mark, I haven't been using that feature because I thought it reduced the area of the image, not just the crispy edges.
This way I can manually crop off the toast and keep the bread.
Jim
Jim
For Imaging:
For Imaging:
- Has thanked: 9145 times
- Been thanked: 6026 times
It does, but by cropping afterwards does the same thingAlbuqshutterbug wrote: ↑Fri Jul 14, 2017 5:20 pm Mark, I haven't been using that feature because I thought it reduced the area of the image, not just the crispy edges.
- Albuqshutterbug
Thank you Franco. Something new and it feels odd.
Thanks Mark. I'll add that to my settings and try it out.
For Imaging:
For Imaging:
