Experiment
- Has thanked: 9307 times
- Been thanked: 6144 times
Experiment
Hello all: this is my first experiment this morning with AR2665 high res. I have lot to learn !
- 113936-final.jpg (171.34 KiB) Viewed 2755 times
- AR12665-final-color.jpg (272.74 KiB) Viewed 2755 times
- Been thanked: 4971 times
Re: Experiment
Franco:
A super shot, it is very difficult when the spot is near the edge, due to the curvature of the sun globe.
What instruments did you use?
- Been thanked: 4422 times
Re: Experiment
Great shot Franco
- Has thanked: 17970 times
- Been thanked: 8905 times
Re: Experiment
Well done, that is the hardest WL shot to take and you have done it very well indeed
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: Experiment
Very nice Franco,I'd say the experiment was very successful :-)
David
David
Re: Experiment
Thank you, Eric, Brian, Alexandra, David and Pepe for your support !
Eric: the scope is the 203mm Airylab HaT. There are many things I still have to figure out.... I am in a learning process about this scope.
- Been thanked: 171 times
- Has thanked: 20779 times
- Been thanked: 10462 times
Re: Experiment
Very good indeed!
- Has thanked: 8543 times
- Been thanked: 8278 times
Re: Experiment
Looks beautiful, Franco. Nicely coloured too.
Stu
Stu
Re: Experiment
Coloring credit to you, Stu. I learned from your Curves tutorial.
Thank you for your nice comments,
- nickatnight
- Albuqshutterbug
- Been thanked: 26 times
Re: Experiment
Very well done Franco.
The rock and hard place comes to mind and you did very well.
Great start.
Jim
Great start.
Jim
Lunt pressure tuned 60mm with 1200 blocking filter.
And Baader 5D solar film filters for all of my lenses and telescopes.
For Imaging:
Celestron Skyris 236M and 236C
Canon 7D, Canon 5D Mark II and Canon T2i IR Modified
For Imaging:
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Re: Experiment
Thank you Jim and Alfred.
Alfred: I am not sure about the specific frequency. This image was taken through a single PST etalon with an optical train that was not what it was supposed to be, therefore I called it an experiment..... I was somehow surprised myself of the result, that in the end is not bad.
We shall see what the next images will bring !
