Various test images with Solar Spectrum RG 0.3A, C8 Edge HD at F/27 and F/35, and C11 at F/27
- Been thanked: 2725 times
Dear All,
Here are some new test images comparing various configurations.
Comparison between F/27 (left image) and F/35 (right image)with the C8 Edge-HD. The F/35 image has been resized to have the same sampling as the F/27 image. Both images are then processed exactly in the same way. Seeing is similar for both images.
The increase in contrast appears significant. As a reminder, a 0.3 FWHM filter has an effective FWHM of 0.5 at F/27 and 0.4A at F/35 :
Full image with the C8 Edge-HD at F/27 :
Full image with the C8 Edge-HD at F/35 :
The increase of resolution between F/35 and F/27 is not negligible.
Now the image taken with the C11 Edge-HD (HAT) at F/27 :
This time the incease in resolution is significant.
Best regards
Best regards
- Has thanked: 9304 times
- Been thanked: 6140 times
Re: Various test images with Solar Spectrum RG 0.3A, C8 Edge HD at F/27 and F/35, and C11 at F/27
That is a great comparison, Christian ! Is it just the contrast ? Detail in the f/35 seems better... or maybe that is just my impression.
All impressive images anyway....
- Been thanked: 4971 times
Hi Christian:
Superb images.
What f /ratio do you recommend me for a setup that I will start to try as soon as the weather lets me.
It is a 10" f/20 TEC Maksutov with a full aperture Aries D-ERF, an ATM 0.45Aº Daystar H alpha filter.
I was planning to try it at f/20 or at f/40 with a Baader 2X Telecentric.
¿What do you suggest ?
Superb images.
Hi Christian,
Very nice and useful comparision work! Very informative for users.
The only questions remain:
can we achieve about the same contrast at F/27 as at F/35 by postprocessing contrast addition?
what will be the final resolution F/27 vs F/35 if the camera has enough sampling at F/27.
For me the F/27 is not necessary worser than the F/35. F/27 allows wider FOV and significantly shorter exposure and, possibly shorter movie cadence. Of course, I prefer to have slower F/D at the etalon and then use a focal reducer if a smaller image scale required.
Thanks for your comparative work.
- Has thanked: 8543 times
- Been thanked: 8268 times
All stunning images, Christian. We're into 6sigma comparison territory here, I think. They are all superb examples of hi-res solar imaging that most of us would be absolutely delighted with.
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Christian, not only are your postings brilliant but educational.
I have put the C11 image on my desktop as a wallpaper for inspiration ( and as a processing template ).
One day ....
David
One day ....
David
- Has thanked: 17970 times
- Been thanked: 8900 times
Wow! both versions I would be ecstatic with
- Been thanked: 171 times
It seems aperture rules.Thank you for the comparisons.
Good old rule.
- Been thanked: 6688 times
outstanding images Christian
- Has thanked: 20767 times
- Been thanked: 10453 times
At the expense of image noise maybe?
Thanks to all :-)
France : indeed, the resolution of the image at F/35 is larger (even if I rescaled it to the same sampling for the comparison). This could increase the contrast of smaller details. Still the contract of larger details (the filaments) is only affected by the effective bandpass of the filter.
Eric : I would say go for F/30, still you would need to find a X1.5 telecentric. So maybe, F/40 with the X2 telecentric and a X0.7 focal reducer ?
Valary : this is an interesting question ;-) It is all about S/N. The more contrast you have at the acquisition, the softer you can process the image. Still, this is a matter of finding the correct balance between exposure time (which increases with F/D), seeing and contrast.
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Hi Christian,
I agree with David that your postings helped me to learn. Thanks.
Alfred
Alfred
- michael.h.f.wilkinson
Absolutely stunning images. The slower F-ratio definitely has the edge
Solar kit: GP-C8 with Thousand Oaks Solar filter, APM 80mm F/6, Lunt Herschel Wedge, Solar Spectrum 0.3Å H-alpha filter, Beloptic Tri-Band ERF (80mm free aperture), Thousand Oaks 90mm ERF, Coronado SolarMax II 60mm with Double Stack Unit. Lunt straight B1800 Ca-K module.
Very very true!christian viladrich wrote: ↑Sun Aug 06, 2017 9:21 am It is all about S/N. The more contrast you have at the acquisition, the softer you can process the image. Still, this is a matter of finding the correct balance between exposure time (which increases with F/D), seeing and contrast.
Alfred, David : it is my pleasure if it can be of any help :-)
Hi Christian. Are you using the RG32 or RG46 solar spectrum filter?
Hi Mark, this is the RG32.
Still need some time to finelly tune it right on on Ha.
Must confess it's a filter i'm very seriously thinking about getting myself...christian viladrich wrote: ↑Thu Aug 10, 2017 6:48 pm Hi Mark, this is the RG32.
