New sunspot on Aug 2
- Been thanked: 1735 times
This was taken just before the clouds moved in. I used the following setup :
Baader 3.8 film + AR152 + 2.5X Powermate + (UV/IR cut + 685 IR pass) + PGR G3 2.8 Mp - the two filters pass a narrow dark red colour.
Lou
Lou
- Has thanked: 9327 times
- Been thanked: 6163 times
- Been thanked: 8907 times
- Been thanked: 171 times
- Been thanked: 4434 times
Re: New sunspot on Aug 2
Very sharp Lou
Interesting filter combo...a sliver of near IR spectrum being passed I assume.
- michael.h.f.wilkinson
Lovely detail in those images
- Has thanked: 8559 times
- Been thanked: 8297 times
Good to see AR2665 back again, though somewhat diminished.
Nice image.
Nice image.
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Thanks, all.
I noticed some years ago that when I bundled these 2 filters they would produce a very narrow bandpass at about 670 nm according to their
spectral curves. The contrast and ability to calm the seeing is very noticeable. I also found that a Baader SII filter has a very sharp (very steep wings) spectral curve that is entered around 670nm which also produces similar results.
Lou
Lou
- Has thanked: 20834 times
- Been thanked: 10502 times
Good shot Lou!
