Today the first try of the new scope. 127mm Bresser Messier F9,8.The regular set up is:
160 mm D-Erf / Bresser Messier 127 F 9,8 / PST Etalon / JMI focusser / Blocking Filter B1200 / 2,5x Powermate / 2 degrees wedge prism / DMK41
20170731_164445 by bart moors, on Flickr
Way much heavier and bigger than the 100 mm Skywatcher, but the EQ5 seems to hold.
AR2670 in H-Alpha and in White light. First use of a Lacerta Herschel wedge. ND3.0 filter, solar continuum / IR-UV Block. The three dots in the upper right corner are dust bunnies. No more time to take a flat because the clouds started rolling in. Thanks for looking!
3augustus2017_BR127_PM2,5x_09-15 by bart moors, on Flickr
3augustus2017_BR127_PM2,5x_09-51_wit2 by bart moors, on Flickr
First light 127mm Bresser
- Been thanked: 6691 times
Re: First light 127mm Bresser
Thanks Pedro and Pepe! I am happy about the scope. A bit unsure about two things:
- the DMK41
- The use of a Lunt blocking filter in combination with a PST etalon.
I'll ask my questions in a separate thread and would be happy to get your advise.
- the DMK41
- Has thanked: 9318 times
- Been thanked: 6156 times
- Been thanked: 4427 times
Superb images for this setup Bart...well done
- Been thanked: 171 times
- Has thanked: 8558 times
- Been thanked: 8290 times
Looking good there, Bart.
- Has thanked: 20813 times
- Been thanked: 10484 times
Nice scope and images! I'm thinking of getting one too.
