Gain Recommendation for ZWO 174mm
- Has thanked: 1640 times
- Been thanked: 878 times
I have tried several different gains but unsure what should be the correct range. I have gamma 50, most recently used gain 80
Suggestions?
Suggestions?
- Has thanked: 20779 times
- Been thanked: 10459 times
Re: Gain Recommendation for ZWO 174mm
With the ZWO I wouldn't use any gain as it gets power from the USB connection, which, electrically is noisy.
- Been thanked: 6688 times
I agree with Mark, I also use the minimum gain with all my cameras (including the ZWO ASI174MM)
Interesting.
Do you guys use 8 or 16 bit dynamic range? And is the gain recommendation when using Firecapture?
Oivind tangen
60N10E
Oivind tangen
60N10E
I always use 8bit
Always 8 bit for me
- Has thanked: 17970 times
- Been thanked: 8904 times
I am guessing the higher frame rate, but on the down side you are losing a lot of greyscale information. I know folks insist that stacking images increases the greyscale dynamic range to 16 bit, but I can only speak from experience. With my Grasshopper the frame rate stays the same between 8 bit and 16 bit, however I capture everything at 16 bit as the dynamic range in the final image is huge compared to the 8 bit version. It makes processing a white light image a dream rather than a fight. But that is just my experience, I know nothing of the physics and others will disagree. I just know the difference
Will have to do a revisit and try this Alexandra, just need the sun now!Montana wrote: ↑Tue Aug 15, 2017 9:23 am I am guessing the higher frame rate, but on the down side you are losing a lot of greyscale information. I know folks insist that stacking images increases the greyscale dynamic range to 16 bit, but I can only speak from experience. With my Grasshopper the frame rate stays the same between 8 bit and 16 bit, however I capture everything at 16 bit as the dynamic range in the final image is huge compared to the 8 bit version. It makes processing a white light image a dream rather than a fight. But that is just my experience, I know nothing of the physics and others will disagree. I just know the difference
So yall use low gain .... what about gamma ???
My normal settings are usually 45 gain.... 1.4ms exposure .... and 1 gamma to prevent clipping
Lunt LS100THA
TEC 140
AP Mach1gto
Lunt b1800 H-Alpha
Lunt b1200 K-Line
ZWO 174mm & 1600mm
TEC 140
AP Mach1gto
Lunt b1800 H-Alpha
Lunt b1200 K-Line
ZWO 174mm & 1600mm
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
I agree with Alexandra that 16 bit "should" give better dynamic range but ... There was an excellent discussion about that on CN started by Emiel Kraaikamp (AS!2 & AS3) stating that the only gain would be noise in most cases. (Should try to find it back) This was mainly for planetary, and probably a little different for solar work were you have extreme dynamic range. I think one should also take into consideration the ADC present in the camera. Most webcams I know use a 12 or 10 bit ADC (ZWO for example in highspeed uses 10bit, in normal speed 12 bit on most cameras). Only exception I know at the moment is the Sony IMX 178 based cams having a 14 bit ADC (but with very small pixels not always very usefull for solar work).
So in most cases 16bit recording will probably (need some expert opinion on this) only give true 12 bit. File size will double, so the question will remain, is it worth it? I should do some testing, unfortunatelly not having much time at the moment.
For Gamma setting: i would only use NEUTRAl (linear) gamma. If not the captured signal will be crippled. Correction can and should be done in post processing.
For ZWO cam: linear gamma setting is 50 (or off in FireCapture)
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
As for "crippling", this depends on the target. For prominences, I indeed use only neutral gamma. But for surface-only videos I turn the gamma down to minimum to better utilize the whole 8 bits of pixel values. This can be seen on image histogram: in my single-stacked setup, a neutral image occupies only 20-25% of histogram's width (i.e. contrast is not that great). With minimum gamma this width is greater, i.e. the raw 10/12-bit values from A/D converter are stretched before being rounded to 8 bits.
This stretching can indeed be also performed during post-processing with similar effect, but I suspect it's better to have this wider range of values before stacking (haven't verified it though!).
Hi Paul,
I think this is the thread you are talking about. It is very interesting!
https://www.cloudynights.com/topic/3303 ... -analysis/
Bart.
Bart.
bart1805 wrote: ↑Mon Aug 21, 2017 8:18 pm Hi Paul,
Bart.
