Hi all,
Yesterday's solar prominence was very large so I made my first solar timelapse using my Lunt LS50THa and Zwo asi-120MMs camera
I took 14 images every 5 minutes. It was a real pain to stack everything together
I wanted to take more image but clouds got in the way around noon. Anyway I think the resulting animation is very nice.
18 August prom animation
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
Re: 18 August prom animation
Great catch!
Here's your prominence realigned with ImPPG:
With a few tricks it shouldn't be. Most stackers have batch mode (AS!3 - just select all videos, drag and drop them on program window; in AviStack2, Stackistry, select and open multiple files). Then I suggest using ImPPG for batch post-processing and automatic alignment of resulting images. I routinely stack and process 200-plus-frame time-lapses, it's no big deal (usually I only have to manually fiddle with stacking settings for a few % of videos).I took 14 images every 5 minutes. It was a real pain to stack everything together
- aligned.gif (797.77 KiB) Viewed 1021 times
- Been thanked: 4427 times
Great animation
