This was the setup I used for this weekend's G-band imaging with an ARIES ERF on a C8, 4x Barlow + 430/10nm + ASI174MM camera:
Imaging was done in between clouds
AR12674 imaged on 2Sep 17
AR12674 imaged on 3Sep17. It has grown larger and filled the full FOV provided by a 4x barlow
I was glad to have these as the seeing condition was poor.
Alfred
G-Band Image from Singapore (New Image added 4Sep)
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Re: AR12674 in G-Band from Singapore
Wonderful shots
Sam
ETX 90 + Badder ND5, Coronado PST, ASI120MM
Old lost Profile : thakursam : memberlist.php?mode=viewprofile&u=544
Sam
- Been thanked: 171 times
- yltansg
Thanks Sam, LauraMS and Derek.
The weather has gone South again today and the Sun is totally hidden.
I am still looking for a G-band image with clearly defined granule edges in and near the active regions.
Alfred
Alfred
- Has thanked: 9145 times
- Been thanked: 6025 times
- Been thanked: 1735 times
Hi, Alfred
I hope the weather improves soon for you. There are some fine details in your work.
I have a question about your set up for these images. I want to set up my c9.25 + full aperture ERF + 2.5X - 4X Powermates for "white light" imaging, I mean where sunspots look like traditional sunspots. So far, any camera filter I've used gives an image that is far too bright for any shutter speed available.
Do you use any other filtration besides your Aries ERF and the 430/10nm CCD filter on your setup for these images?
Lou
Lou
- yltansg
Re: G-Band Image from Singapore (New Image added 4Sep)
New addition from today's session (4 Sep 17). This sunspot has grown rapidly and worth watching....
- yltansg
Hi Lou,gabrieli wrote: ↑Mon Sep 04, 2017 11:36 am Hi, Alfred
Lou
I know what you mean. I have experienced it myself. What I did was to place a ND filter in the light path. Previously I placed it immediately after the SCT before the diagonal and it cracked. Now, on Valery's advice, I placed it (the ND filter) after the 430/10nm filter before the camera. I have bought the following 3 filters for my experiments:
High Point Neutral Density Filter 50% Transmission ND96-0.3 - ND96
High Point 1.25" Neutral Density Filter 25% Transmission ND96-0.6 - ND61
High Point 1.25" Neutral Density Filter 13% Transmission - ND96-0.9 - ND91
Have fun
Alfred
