Dear Friends,
Here is todays attempt to shoot with Omega 394NB filter combined with Meade Blue CCD filter. I am not sure whats problem but i am not able to see CaK features with this setup. I am using PST by removing ERF & Blocking filter. with ASI120MM i just get full disc on sensor.
I am guessing PST etalon must be transmitting in CaK / CaH wavelengths too, so adding 10nm Passband centered on 394 might help me to give better contrast, but unfortunately that don't seems to work, so i added Meade CCD blue filter which ~ cuts at 395, but still the resultant is same.
Anyways i am getting better resolution (i guess) with 40mm PST lens. here is the results, in past i had similar result with AT66 refractor with Badder ND5.
Sun Full disc 4-Sept-2017
- Sun 4-Sept 2017 / Coronado PST (by removing blocking filter & ERF) + Omega 394NB + Meade blue CCD filter + ASI120MM (exposure 8ms)+ Stacked 25% of 500 frames in AS!2 + processed in IRIS & FSViewer.
- sun-4-sept-2017-Final.jpg (550.87 KiB) Viewed 7848 times
Sam
ETX 90 + Badder ND5, Coronado PST, ASI120MM
Old lost Profile : thakursam : memberlist.php?mode=viewprofile&u=544
Sam
