what level settings for false color cal k-line
Questor
Oh, I get it now!
Oh, I get it now!
Been thanked: 2 times
Post by Questor »
Just getting advice on levels for mono cal K-line images
thanks for y'alls input,
Chris
Lunt LS100THA
TEC 140
AP Mach1gto
Lunt b1800 H-Alpha
Lunt b1200 K-Line
ZWO 174mm & 1600mm
danpro1
Has thanked: 21 times
Been thanked: 29 times
Re: what level settings for false color cal k-line
Post by danpro1 »
Hi Chris,
If you are asking about the settings to colorize a monochrome image in CaK, here is what I use in Photoshop CS2: Adjustments/Color Balance, then I set Cyan to -75, Magenta to -100 and blue to +25. Example attached.
I hope that this helps.
Daniel
Questor
Oh, I get it now!
Oh, I get it now!
Post by Questor »
yes !!! thank you so much .... i've got tons experience with h-alpha but just got a K-line 1200 lunt wedge and wasn't sure the best coloring....
Thanks again !!
Chris
Lunt LS100THA
TEC 140
AP Mach1gto
Lunt b1800 H-Alpha
Lunt b1200 K-Line
ZWO 174mm & 1600mm
