ARs on Sept 6
- Been thanked: 1735 times
ARs on Sept 6
I hope these ARs put on a good show near the limb.
Lou
Taken at 2000mm with an AR152
Taken at 4000mm with an AR 152
Lou
- Ibbo
- Has thanked: 2443 times
- Been thanked: 1650 times
- Has thanked: 9327 times
- Been thanked: 6163 times
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Re: ARs on Sept 6
Amazing activity, lovely images
Robert
Robert
- Been thanked: 4434 times
Re: ARs on Sept 6
Great shots there Lou
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
- solarchatted
- Has thanked: 12 times
- Been thanked: 10 times
Re: ARs on Sept 6
I am new to this forum - sent here from Charlie Bates Facebook Page and I am just a dabber - although from many years on and off ... and poor!
Anyway, which wedge did you use for these images?
I am personally thinking to get the Altair Solar Wedge [I am not really into solar at all!] so I can do something when weather here in the Cloudy UK is ... guess
... cloudy! ... but usually get a few decent hours during the day or before sunset for Solar.
I am still not sure if Altair Wedge would be focusing OK with the AR152 988mm and also using various filters and or a 0.5x reducer and Orion 0.8x Flattener - to get the scope down to wider fields.
Altair is doing a great job with Cameras and I guess this wedge too and at the same time trying to keep prices a bit lower than average.
i.e. trying to use the same scope for most of observation and imaging.
Any help from you experts?
M
M
SolarChatted
https://astronomo.space/my-images/the-sun/
https://www.youtube.com/@Astronomo_Space
Solar Gear:
Bresser AR90/900 + PST mod + SW Auto Focuser ...
Sometime I use Explorer Scientific AR152/988 + Used once only... Altair 2" Solar Wedge (very good indeed)
Will try and do it justice when I can with the help of various filters, Baader 1.25" Solar Continuum 10nm is one.
SW 72ED Pro - fixed 'stock faulty' focuser ... 'I think' !
Solar Gear:
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1387 times
Re: ARs on Sept 6
Charlie died in 2007. The program is named in memoriam. Everyone makes that mistake...just letting you know. Im Stephen Ramsden, Director.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
- solarchatted
Re: ARs on Sept 6
Hi Stephen
Sorry to hear that and thank you for informing me.
SolarChatted
Solar Gear:
Solar Gear:
- Been thanked: 4981 times
- robert
Re: ARs on Sept 6
I guess any wedge is good. I use a Lunt one and also Baader Astrosloar film ND3.8 for imaging and ND5 for visual. Baader astrosolar film is cheaper and very nearly as good. To see white light granulation as in these images you need more magnification so Barlows or Televue powermates are what you need not reducers and flatteners. However to do full disk images a reducer or flattener may be needed depending on the camera you use. (according to chip size).solarchatted wrote: ↑Wed Mar 14, 2018 12:01 pm I am personally thinking to get the Altair Solar Wedge [I am not really into solar at all!] so I can do something when weather here in the Cloudy UK is ... guess
I am still not sure if Altair Wedge would be focusing OK with the AR152 988mm and also using various filters and or a 0.5x reducer and Orion 0.8x Flattener - to get the scope down to wider fields....
Any help
I expect you can get away with one scope a white light filter, film or wedge and a couple of lenses and be busy with all sorts of solar imaging for a long time, Good luck
Robert
Re: ARs on Sept 6
Hi, Solarchatted
I almost lost your question in the middle of this old post. Sorry about the delay.
For these white light images, I used Baader 3.8 film in front of my AR152 refractor.
Lou
Lou
- solarchatted
Re: ARs on Sept 6
I never said thank you for your replies.
Gosh, almost a year passed and I am back trying to get more into solar!
I might get a Lunt 50 - if I can afford it.
Sorry again - I am too busy trying to put food on the table these days more than usual.
SolarChatted
Solar Gear:
Solar Gear:
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4881 times
