23092017_H-Alpha PST Mod Doublestack
Two images of today.
Bresser 127-35nm filter-pst etalon 1-circular polariser-pst etalon 2-Lunt BF1200-Powermate2,5x-3 degrees wedge-Grasshopper3.
Practice makes it a bit easier to focus with the doublestack. The results:
230917_14h07m_Br127_DS_PM2,5x_AR_PS by bart moors, on Flickr
230917_14h07m_Br127_DS_PM2,5x_AR_PS_Inverted by bart moors, on Flickr
Thanks for watching! Bart.
- Been thanked: 1735 times
Re: 23092017_H-Alpha PST Mod Doublestack
Hi, Bart
This is very impressive. Right now, I'm trying to decide how to use a double stack arrangement with a large ERF setup. Single stacking either a PST etalon or Quark Combo doesn't cut it. I'm playing with double stacking a PST etalon with my Quark Combo but so far the view is a bit dim.
One hesitation I have in buying another PST for a DS setup is that the current PST looks a bit different than the one I cannibalized for its etalon.
Would you know if the back and front threads between the current PST etalons and older PST etalons are the same?
Lou
Lou
Hi Lou,
Thanks!
As far as I know the threads have stayed the same, so that would be M51x1. Maybe somebody else can confirm. Bart.
Thanks!
These images are beautifully processed, full of detail and very smooth, nice work
M50x1
Pfffiiieuuuw Valery, thanks for the correction!! It is off course M50x1.....
Lou,
As far as I can see, the latest PST have an anodised "gold" tube rather than the original brass tube.
The eyepiece holder as previously mentioned also appears to have been increased in height - making it more difficult to focus a camera and image.
The etalon assembly, black box design (and the over load of Loctite!!!) is unchanged.
- Has thanked: 8559 times
- Been thanked: 8290 times
Back to the images........very nice indeed! The DS PST mod appears to be working very well.
- Has thanked: 20819 times
- Been thanked: 10489 times
Super detail from this setup, it's working really well!
Thanks Alexandre, Stu and Mark!
@Mark: is the only difference between this DS experiment and the one you tried, the addition of the circular polariser?
Don't really know Alex if they are really uniform or if Photoshop helps a lot. Plus it is a cropped image, not using the whole of the CMOS.
