The T250 at F/D 35 in Ha
- Has thanked: 714 times
- Been thanked: 496 times
The solar T250 is designed at F7, to be combined to a 4x telecentric and so reach F/D 28 for Ha imaging.
In the hope of better contrasts, it has been pushed to F/D 35.
The resulting FL is about 9m.
Here, a mosaic of 3 captures.
Alex
2017Aug29
Solar newton T250
Telecentric x4 + GWK x1.25
Solar spectrum
ZWO ASI174
Alex
2017Aug29
Solar newton T250
Solar spectrum
ZWO ASI174
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Re: The T250 at F/D 35 in Ha
Very fine detail indeed, beautiful
Robert
Robert
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Beautiful Alex! Are you using a 0.5 Solar Spectrum?
The Solar Newton is intriguing. Is it difficult to hold the collimation?
Bart.
Bart.
- Has thanked: 1640 times
- Been thanked: 878 times
- Been thanked: 8791 times
Nice capture, Alex! Very smoothly processed.
Too bad you didn't show the other two larger spots on the sun.
BTW What is your SS etalon?
- Been thanked: 1735 times
Hi, Alex
Your second image looks like heaven to me. As Valery has noted, your image has such a smooth , velvet-like texture in places.
I would also like to know which Solar Spectrum filter you used here.
Lou
Lou
Hi!
Thank you for the comments.
I disassemble the secondary after each session, because I'm afraid of dust. So, I collimate at every session.
Even with the secondary kept mounted, I check the collimation at every session.
Valery, I didn't capture the 2 other spots, because when they appeared, I captured them in KLine.
And the days after, the weather was bad. Finally, I was back at work. So, unfortunately, I missed them.
I'm not a fan of inverting the images during the processing. But I must confess that this technique enhance the 3D effect.
The Solar Spectrum is an ASO 0.3A.
It should be about 15 years old, or maybe more.
But there is not only the SS. I push the pics under photoshop, but try to not overpush the contrast.
CS
Alex
CS
Alex
- Has thanked: 8418 times
- Been thanked: 8163 times
Very nice images, Alex. Beautifully resolved fine structures.
- Been thanked: 4904 times
Alex:
Superb processing, you got beautifully smooth details.
- Has thanked: 9145 times
- Been thanked: 6025 times
- Has thanked: 20440 times
- Been thanked: 10246 times
These came out really well Alex!
