Today's spots captured with home made 3D printed truss tube Wollensak D153mm F8 achromat, Quark Chromo single stack with ASI174MM.
2000 frames sequences each. Stacked 150 best frames. Processed with ImagesPlus and tweaked a bit in Photoshop.
Average seeing according to SSM was around 2.6 in a range from 1.1 to 3.6.
I have moved from double stack Quark-Lunt LS50F to Quark only, to achieve significantly shorter exposures and max frame rate with ASI174MM. It is showing up in the details in comparison to my earlier DS images.
Here are some examples of the spots, more you can find in my Flickr album
AR12681 B/W and artificially colored
AR2681 D153 Quark__2017-09-29_PDT_12-33-08-0159_L_g2_ap504 150f psp by Frank T, on Flickr
AR2681 D153 Quark__2017-09-29_PDT_12-35-10-0410_L_g2_ap494_150f psp c by Frank T, on Flickr
AR12682 B/W and colored
AR2682 D153 Quark__2017-09-29_T_12-39-51-0794_L_g2_ap494_150f psp by Frank T, on Flickr
AR2682 D153 Quark__2017-09-29_T_12-39-51-0794_L_g2_ap494_150f psp c by Frank T, on Flickr
AR12683 B/W and colored
AR2683 D153 Quark__2017-09-29_PDT_12h30m44s-0450_L_g3_ap503_150f psp by Frank T, on Flickr
AR2683 D153 Quark__2017-09-29_PDT_12h30m44s-0450_L_g3_ap503_150f psp c by Frank T, on Flickr
Thanks for looking and feel free to comment
Frank
www.flickr.com/photos/photon_chaser/
AR12681, AR12682 and AR12683 in H-alpha on September 29th 2017
- Been thanked: 8793 times
Re: AR12681, AR12682 and AR12683 in H-alpha on September 29th 2017
Wow! some great shots there Frank, I love the last ones, quite spectacular detail, very nice indeed
Thank you Alexandra, I appreciate your kind words. The Sun is very interesting now, I hope I capture more of it during the weekend.
Frank
Frank
- Been thanked: 4340 times
Very sharp pics Frank...well done!!!
Thanks Brian, I am still tweaking the workflow. Most of the things learned here, from you guys and girls :-)
Slowly getting to the maximum capabilities of my current system, so soon I will be in Alexandra's position of channeling some funds to get new gear. Valery will like it probably ;-)
Frank
Frank
- Been thanked: 171 times
Terrific pics Frank a wet arvo here so I perused some of your Flickr albums.Love the set up that's a long train to keep rigid.Good luck with future mods I have resisted going larger than 150mm as I only have conditions here once or twice a year where even that aperture is viable.Mind you I diverted to Canon telephotos so it may have been more economical to stick with Solar mods.
Derek
Derek
- Been thanked: 10248 times
These work well Frank!
- Has thanked: 8418 times
- Been thanked: 8165 times
Nice ones, Frank. Lots of nice detail in these.
