Hello,
For a white light observation with a solar Wedge, is best an Apo or ED lens refractor,or an achromatic refractor ? the focal lenght is indiferent? best more aperture, for example a 120mm F/8 achro. refractor that an 80ED F/7.5 or F/6 ? the CA is not intrusive in the achro refractor with the solar wedge ? all questions is for visual observations
thank you in advance for your opinion and experience
pluton
Apo or Achromat.refractor for visual WL.
- Has thanked: 173 times
- Been thanked: 615 times
Re: Apo or Achromat.refractor for visual WL.
Pluton,
On the assumption you are also using a Continuum (or OIII filter) with the wedge - there's no need for an APO.
I use both the ED80 and the TS102 f11 with no issues.
For solar works it is MUCH better to have a larger achromat than a smaller APO! You will much more per $.
Or better to spend the difference in the cost between APO and Achro (the same size) for a better filter, say, for a
good Quark or even better filter.
APO is for planetary observing (visual) and deep sky imaging (wide to middle field).
Hello,
Thank you for your response.
But dont´like the visual image with the Continuum filter, only with the polarizer(plus a ND3 filter) filter, there is too much CA with the Achro refractor?
For example, an Achro Celestron Omni 120mm F/8 can be a good alternative to a ED80 refractor for visual observations?
I did, these have more resolution, but,,,, it have CA bothered me ?
I think that a ED or APO refractor have more contrast in the image...but, I like looking solar granulation...., 80mm is sufficient for this ??
Thanks again for tour advice.
Pluton
Pluton
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
In spite of the residual CA the 120mm achro will be much better than the smaller 80 APO for WL. I have a 150mm achro and a 90mm apochromat, both are fine and show lot of details however the achro wins in resolving fine structures in granulation and penumbrae.
Based on my experience, for a 120mm f/8.3 filtering the CA is not strictly necessary in observing the Sun in WL. Surely there is no need of a heavy filter as the Baader Continuum (unless you want to do some imaging), visually a light yellow W8 or a Baader Fringe Killer will work fine as well.
Raf
