A few from Oct 1st
Has thanked: 64 times
Been thanked: 4407 times
A few from Oct 1st
Post by MapleRidge »
Good evening everyone...
We had another clear fall day on Sunday and as usual, headed to the observatory after breakfast to do some observing and imaging.
The activity continued with AR's 2682 and 2683 near mid disk and AR2681 near the western limb. The large serpentine filament continues to wind around AR2682, and there were several smaller proms as well. The white light details in the sunspots was very beautiful to view. Seeing was moderate, so I limited the full disk to all three bands and only worked in Ha for the higher resolution images.
First up are the Ha full disks through the LS80T/DSII, captured with the PGR ICX674 CCD chipped camera. Offered in 3 palettes:
The next set of images were taken through the Istar 150mm, F8 OTA with the Lunt Solar Wedge/Baader Continuum Filter for the WL images and a Lunt B1800CaK Wedge/Baader CaK filter set, with the ZWO ASI1600MM camera:
The higher resolution Ha images were taken with the CR-150/DSII/B1800Ha modded scope and the ZWO 174MM camera. The mosaics below were assembled from a half dozen separate images and presented in a monochrome, inverted and colourized versions:
This covers off the Sunday session...still working on Mondays harvest.
Questions and comments are always welcome.
Has thanked: 8523 times
Been thanked: 8253 times
Re: A few from Oct 1st
Post by Carbon60 »
A lovely set of images, Brian. Nicely resolved details in the Ha images.
Has thanked: 17924 times
Been thanked: 8891 times
I really do like the last set, when opened in a new tab and viewed at full size the detail is very good, nice work Brian :bow :hamster: nothing but cloud here, I have never known it to be grey for so many months.
Has thanked: 9292 times
Been thanked: 6127 times
Post by ffellah »
A very nice set, Brian
Stu, Alexandra, and Franco...
Many thanks to each of you for your comments :bow
Alexandra, I hope you get some sun soon so that you can keep sharing your views! After the wets spring and summer I can sympathies with your situation. We at least seem to be getting a spell of nice weather for the fall.
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
Nice ones Brian
Has thanked: 20738 times
Been thanked: 10436 times
These look good Brian! Glad you are having a sunny fall.
Thanks Mark and Derek!!!
