walk on the surface of the sun on October 4th.
banjo
Has thanked: 2098 times
Been thanked: 2872 times
Post by banjo »
Hello everyone,
a small walk on the surface of the sun on October 4th.
the clouds too quickly arrived to make the whole surface.
Paul
click on the link for video
https://vimeo.com/236737079
Has thanked: 9294 times
Been thanked: 6129 times
Re: walk on the surface of the sun on October 4th.
Post by ffellah »
A very nice surface image, Paul ! Great detail....
Franco :beanie:
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Nice swirling patterns with fine structures beautifully captured, Paul.
bart1805
Been thanked: 1 time
Post by bart1805 »
Nice one Paul. I checked out your site to look at your Mod. What kind of Glasspath are you using?
Bart.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Beautiful image Paul...well done :bow
Has thanked: 17925 times
Been thanked: 8891 times
Very nice picture and I enjoyed the walk around on the video :bow :hamster:
banjo
Post by banjo »
Hello to all
thank you for your nice messages.
Bart. It's This one http://laclefdesetoiles.com/applanisseu ... ark-v.html
Paul
bart1805
Post by bart1805 »
Thanks Paul! I just noticed that a 150 mm f8 Skywatcher is just a fraction heavier than my127 mm Bresser. So if I can catch one second hand I might give it a try.
Where did you mount the glass path? In the 2 inch nosepiece you screw in the etalon?
Thanks again, Bart.
banjo
Post by banjo »
just before etalon
in connection 2 "Focuser --- >> etalon Pst
view towards the lens (150mm)
circlips house (bof)
view against the etalon Pst
Paul
bart1805
Post by bart1805 »
Thanks Paul, hope I can ask you some other questions.
How did you calculate the distance between the glasspath and the etalon?
And how did you calculate the exact position of where in the light path the glasspath had to be positioned?
CS, Bart.
Hi Bart...
I am not that familiar with these correctors, and have read the detail on the Baader site.
I was wondering if they are serving as telecentric lens, or used to extend the focus to permit the modded filter to reach focus?
Thanks for the information on your system,
bart1805
Post by bart1805 »
Hi Brian,
I would use the 1,25x glass path to make the beam a f10 beam instead of a f8 beam. The front lens of the etalon provides a parallel collimated beam to the etalon. But it works when the light that enters the etalon is f10. So you have to go from f8 to f10. The difficult part for me is where to put the glasspath so that it does not work as an aperture stop. But Paul is the one who is definitely more of the expert here, it is his system.
Another way would be to remove the front lens of the etalon and put a 4x telecentric before it. But I have learned here that airspace etalons don't work that well in a telecentric beam.
Bart.
Hi Bart and Paul...
The use to get to f10 makes sense for the PST etalon. Thanks for the update.
I wasn't paying attention to who made the posts on the thread, so I best thanks you both ;)
Has thanked: 20740 times
Been thanked: 10439 times
Looks good!
banjo
Post by banjo »
Hello everyone ,
I put the glasspath here because I did not see better results by sticking it against the front lens of the etalon.
this solution has been used for a long time by other astam here.
have a good day
Paul
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
I used this glasspath in front of my telecentric x4, to have a total equivalent of x5. Works well.
CS
Alex
bart1805
Post by bart1805 »
Hi Paul, I allready found a relatively cheap 150mm F8 Skywatcher. So at the moment I am rebuilding it into a 150mm PST mod. And will use the same setup you described, so with the 1,25x Baader Glasspath. Thanks for showing me the way!
Bart.
