I bought the LS80THa/DSII https://luntsolarsystems.com/product/ls80haptdsii/module from Lunt in the hopes of increasing contrast in my solar images. Installation was fairly straight forward. But when I took my first images I noticed some strange bands:
I tried to refocus. Started to pressure tune both etalons from scratch but I always got these bands. Took MANY images in the hopes that it's maybe only temporary. Took images in the afternoon again. But always with the same result. Does anybody know what's going on and how to fix this?
Thanks
Weird bands with LS80Tha/DSII
- Been thanked: 1735 times
Re: Weird bands with LS80Tha/DSII
Hi, Mark
These bands are called Newton's rings and are common with some cameras. The solution is usually to tilt the camera slightly. Some people use a tilter specifically made for this purpose. One of the more economical ones is by ZWO shown at
https://astronomy-imaging-camera.com/pr ... t2-tilter/
Note that you also have to buy a snout to fit into the telescope tube. If you have a ZWO camera, the camera will mount directly onto the device. If not, you have to buy a T2/1.25" holder for it
Lou
Lou
- Has thanked: 8415 times
- Been thanked: 8161 times
As Lou says, tilting the camera will usually solve the problem. This is common and nothing to be concerned about.... an easy fix.
- Has thanked: 173 times
- Been thanked: 615 times
As others have already said, the solution is to use a tilter in the optical train.
I assume you are using an ASI camera?
- The Sun?
Thanks everybody.
It's just weird that I didn't see these before (single stacked). Could it be that the additional contrast that I get with the second etalon makes this more visible? Or did the addition of the DSII create this effect?
Ordered the little tilter. I am using a T2/1.25" adapter for my Point Grey camera and can probably put the tilter between that and the diagonal.
- Dave S
- Has thanked: 5 times
- Been thanked: 19 times
Narrower bandwidth and higher focal ratios will generally exacerbate the problem. And it will be different for different cameras. So putting on the DSii will usually make it worse, and putting on a barlow will make it worse.
