Today's SUN (20171027) | Coronado SM90II problems
- pedro
- Has thanked: 14 times
- Been thanked: 6749 times
WEBLINK:
http://re.apaaweb.com/sun_h_alpha_2017-10.html
My Coronado SM90II was recently serviced by Meade but I'm still getting low contrast images with the TV101. Any ideas?
Can it be a focal ratio issue, the TV101 is F/5.4. Should I use it with a larger focal ratio (F/10)?
IMAGING SETUPS
IMAGING SETUPS
SUN (20171027) H-alpha DISK & PROMS (11:00 UTC). TV101 F/5.4, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20171027) H-alpha DISK & PROMS (11:00 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20171027) H-alpha DISK & PROMS (11:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20171027) CaK PROMS (11:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20171027) WL, CaK & H-alpha (11:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
WEBLINK:
IMAGING SETUPS
IMAGING SETUPS
Pedro Re'
- pedro
Re: Today's SUN (20171027) | Coronado SM90II
Coronado SM90II
- coronado_SM90II_SM40II_20171027-01.jpg (1022.25 KiB) Viewed 2562 times
- coronado_SM90II_20171027-12.jpg (1.25 MiB) Viewed 2562 times
- coronado_SM90II_20171027-09.jpg (1.41 MiB) Viewed 2562 times
- coronado_SM90II_20171027-03.jpg (1.23 MiB) Viewed 2562 times
Pedro Re'
- Has thanked: 20948 times
- Been thanked: 10588 times
It's just off band for your local conditions (sadly) Pedro. F-ratio isn't going to do much I think. The shots are off band; if they were on-band but lacking in contrast a longer focal ratio may help the blocker with less continuum leakage. Would be interested to see a shot taken with it before Meade has fiddled with it. Short of totally replacing the plate spacers, which I seriously doubt they have done, I don't see how they could do anything to it to improve it on what it was originally. I think that all that has happened is that somebody has wiped it with a cloth
You do have a nice collection of images though, and the other Ha shots do show what the on band disks should look like.
- pedro
Thanks for the comments Mark
Before it was worse or maybe not. Check out these images (before servicing)
SUN (20170205) H-alpha DISK & PROMS (10:30 UTC). TV101 F/5.4, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20170216) H-alpha DISK & PROMS (10:00 UTC). TV101 F/5.4, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
What do you think?
I get much better results with my other etalons from Meade (old and new)
What do you think?
Pedro Re'
Re: Today's SUN (20171027) | Coronado SM90II problems
Hmmmm. I don't see no difference in the before and afters. Will it work better as a double stack maybe?
- pedro
Thanks again Mark
It's a good suggestion. I will have to try it
Pedro Re'
- Been thanked: 171 times
Good luck Pedro.These Ha etalons are very temperamental.
- Has thanked: 18105 times
- Been thanked: 8941 times
Lovely shots Pedro but yes, the SM90 is off band, that is bad luck, hopefully it will work better in double stack
- pedro
Thanks guys
I tried it again today and definitively it's off band
It was serviced in the Mexico Meade factory (150 US$ repair service)
As Mark mentioned I guess they only dusted the etalon
Now I have a big paper weight...
Visually in not as bad though
Pedro Re'
They're just very sensitive to local conditions. I bought Walters SM90ii etalon off him 3 or 4 years ago, in Wolfhalden at >700m altitude it worked great, however when it ended up in Brierley Hills (~100m altitude) it was way off band and nothing I could do would bring it on band. Maybe these Mexican etalons work great in Mexico City (2500m altitude) but then are out of spec for us folk closer to sea level? Perhaps this is why the Isle of Man Coronado etalons are 'better' as they are better suited to more sea level environments?
Hi Pedro,
F/5.4 is too fast for the blocking filter! Lunt suggested to have at least F/7 for blocking filters.
My experiments showed me that contrast improves with F/D decreasing up to about F/12.
Also, with temperature drop the blocking filter's bandpass shits more to the blue.
So, even more important to have a slower F/D at the entrance of the BF.
Any tilt in the focuser will also shift the BF bandpass boundaries to the blue.
Hope this helps.
Hope this helps.
- pedro
Thanks Valery & Mark
I use my TV101 (F/5.4) for most of my FD imaging. I tested all my Coronado Etalons today and the results are very interesting (I will post the images later on today)
Using the same OTA the contrast and details on the chromosphere vary a lot. The SMIIs (Meade) are significantly worse than the pre-Meade etalons (at least the ones I have)
I will have to try the SM90II with a longer Focal Ratio but I suspect that I will get low contrast images. The Pre-Meade SM90 I had was great at F/5.4 (TV101)
Pedro Re'
Pedro,
I too have had a pre-Meade SM90 etalon. It was VERY contrasty. The most contrast air spaced etalon I have ever seen.
Countless times I have regretted about my crazy decision to sell it.
OK, back to your problem. Try to use at least 1.5" Barlow prior to the BF.
If you have another etalon, then this low contrast etalon is a best choice for DS. With wider etalon your DS will have the largest sweet spot.
With narrower etalon - the smallest sweet spot. So, you do not loose! This is a best ace for the DS!
- pedro
Thanks Valery. I will try do it, using the SM90II for DS
I also regret selling my pre-Meade SM90.
Pedro Re'
- pedro
Thanks Mark
You might be right. Using a SM90 at 2500m or at sea level is not the same thing. They should now better, or maybe not...
best regards
best regards
Pedro Re'
Any news Pedro?
- pedro
Yes Mark
They want me to return the etalon to be repaired free of charge. The only problem is that I have to do a temporary export and that will cost at least 500 US$... Not sure what to do
Pedro Re'
- Been thanked: 5016 times
Pedro:
The Mexican Meade factory is situated at almost sea level, (near San Diego but on the Mexican side) so the altitude is no problem.
BTW, I have a Solarmax 90 and when I got it home it did not perform well because it was out of band, so what I did to get it in tune was to mark where the pin is, then took the pin out and while looking at the sun I slowly screwed the pressure tuner out a few holes and tested, then got to the original pin place and checked again and then screwed in a few more holes (from the place where the pin originally was) until I got more contrast, when happy I placed the pin at the middle of the turning sector and tried again moving the etalon at every posible place permitted by the pin.
I was careful not to get too much pressure on the etalon by screwing it to much, just a couple of holes more.
I also moved a bit more the tilting hinge, so that it moved the same amount up and down, and when at the center, the gap all around the two etalon parts held by the hinge were perfectly parallel, for that I used a feeler gauge and an Allen wrench so to place the 2 parts parallel, this also helped a lot to get more contrast and less hotspots.
The BF´s are also very important, so I tried the ones I have (BF10, BF15, BF30), being the BF15 the one that gives a more contrasty view, though I did install the BF30 because it gives a more even field.
I remember David Lunt, Bill Dean and myself, testing many 40mm Coronado etalons, so to match a pair for using at my home observatory that is at 2250 meters above mean sea level, we did the pairing at the Riverside Telescope Making Convention many years ago, we even paired the BF10 among many that he had, so the pairing was done at high altitude, the RTMC was held in a place near 7000 feet above sea level.
I still keep this paired etalons and are really good for its size, I have them mounted on a 76mm f/6.4 TeleVue refractor.
Pedro, this was my experience and did it at my own risk, but it worked nicely.
Abrazo,
Abrazo,
- Has thanked: 65 times
- Been thanked: 4459 times
Hi Pedro...
I am at a loss to make any suggestions, but a relatively easy test would be to use a barlow with the scope, or test it on a scope that is F10 or so just to eliminate the focal ratio being the culprit.
Good luck finding a fix!
- pedro
Thanks Eric and Brian
Eric: I already removed the pin and tried it with the pressure tuner in several positions. It seems that this is not the issue
I still have to try other BF (tried only the BF30). I also suggested that another repaired etalon (SM90II) could be sent to me and I would return the one I have. I'm still waiting for an answer.
Thanks for your comments
Pedro Re'
