Does a reducer work to achieve F10?
bart1805
Been thanked: 1 time
Post by bart1805 »
I learned here that an air spaced etalon in a telecentric beam is not a good idea. But how would this solution work?
For example a skywatcher Mak 180 mm F15. If you use a 0,67x focal reducer and then attach the PST etalon, would that work?
Thanks! Bart.
Has thanked: 20738 times
Been thanked: 10431 times
Re: Does a reducer work to achieve F10?
The maths is never that simple - what spacings would you use?
bart1805
Post by bart1805 »
Don't know Mark. Would have to calculate that. But would it theoretically work and has anyone ever tried it?
In theory, as always, yes. But to work best you need to know the numbers...
bart1805
Post by bart1805 »
For sure Mark, you need to calculate the correct numbers. But that can't be as difficult as landing a man on the moon (-;
But it seems to be a rather simple solution to use a pst etalon with for example a Mak 180. On this forum a lot of different mods, but have not read about this one.
Try it. Just need that reducer the correct distance infront of the PST collimating lens. A bit of trial and error should do it.
bart1805
Post by bart1805 »
marktownley wrote: Sat Oct 28, 2017 8:09 am Try it. Just need that reducer the correct distance infront of the PST collimating lens. A bit of trial and error should do it.
Hi Mark, this time a question not about the SW Mak 180 but about the Intes 703. Just realised that I made a mistake in thinking I could just put the PST etalon behind the 703 because it is a f10 telescope. Yes, it is a f10 scope, but the beam will not be a f10 beam....
Am I right that I need a telecentric 3x? Baader, Airylab and Beloptik are then the usual suspects.
Then remove the front lense of the etalon and also remove the back lens? I am a bit confused because on the Airylab site I read that one should remove both lenses and allways thought it was only the front lens which had to be removed.
Thanks in advance! Bart.
Hi Bart, In this instance I think I would not bother with a telecentric but run the pst etalon (with collimating / re-collimated lenses) on the back of the Intes. If you don't like you can always get a telecentric afterwards and try it that way. Mark
bart1805
Post by bart1805 »
Thanks Mark, will see what happens.
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
Bart,
The 703 is an f10 Mak, why do you think it will not provide an f10 beam to the PST etalon assembly?
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
I believe the f/10 beam from the Mak should be fine, but the real problem is having enough back-focus (~200 mm for PST). You'd need to check how far you can pull the focal plane out (plus there's the effect of changing effective f.l. when the distance of Mak's mirrors changes).
My software:
My images
bart1805
Post by bart1805 »
Merlin66 wrote: Wed May 02, 2018 1:40 am Bart,
Hi Merlin, is the secondary f10? Back to primary Maksutov school for me maybe... Thanks! Bart.
bart1805
Post by bart1805 »
GreatAttractor wrote: Wed May 02, 2018 7:24 am I believe the f/10 beam from the Mak should be fine, but the real problem is having enough back-focus (~200 mm for PST). You'd need to check how far you can pull the focal plane out (plus there's the effect of changing effective f.l. when the distance of Mak's mirrors changes).
Backfocus is huge. About 250 mm. So that should be enough.
GreatAttractor
bart1805 wrote: Wed May 02, 2018 8:06 am is the secondary f10?
Actually, f/10 is the effective focal ratio of the primary-secondary combination (so you're good to go). E.g. in an f/15 MCT there may be an f/3 primary and an f/5 secondary.
My software:
My images
Astrograph
Been thanked: 46 times
Post by Astrograph »
PST etalon with its collimating lens on the back of an F10 scope should allow it to work correctly. Obviously a front ERF is needed on the Mak.
RodAstro
Has thanked: 286 times
Been thanked: 399 times
Post by RodAstro »
I realise you have moved away from the first question will a reducer work but I will just add to this first question, most reducers are based on a simple petzval (not a true one) lens and although it may work be aware that the elements in the reducer tend to be bonded and will separate if they get near 100deg before that the glue will be damaged if the temperature gets high.
For a simple alternative use a reasonably long focal length air spaced lens 60mm or above inside the tube.
It does work I am using a 80mm f7 inside my scope a 150mm f15 to bring it to f8 you also have less distortions and no vignetting.
Petzval did play with air spacing to improve the image and corrections but I find no need if you use a longer focal length lens it just needs to be bigger and further inside focus but much better than any commercial 48mm reducer I have tried.
I'm sure there are more expensive reducers that are more complex and will work well but they are designed for set f ratios and would you like to chance them in a solar scope?
The other thing to remember it will amplify any distortions your scope already has as the field gets wider
bart1805
Post by bart1805 »
@rodastro, greatattractor and astrograph.
Thanks! Hope to be able to test it on Sunday. Will let you know the results.
RodAstro
Post by RodAstro »
Good luck Bart hope it works well
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
I can't make an extensive answer here, but you can dig the question here :
http://astrosurf.com/viladrich/astro/in ... lar/FP.htm
If we go back to the initial question : is an F/15 scope + reductor giving F/D 10 OK with a PST (and its collimating lens) ? Then, the straight answer is yes. In other words, it does not make any difference if you have a native F/10 beam, or if you reach F/10 by the addition of Barlow lens or a reducer.
Then, there is another question : is a telecentric beam "better" than a "collimating beam" ? You can find some elements of answer in my web pages.
If you have a telecentric beam, it should be > F/30 for mica-space etalon and > F/45 for airspace etalon (e.g. PST without its collimating lenses)
There is also the question of back focus available which might make some setups feasible or not.
Hope this helps.
bart1805
Post by bart1805 »
christian viladrich wrote: Thu May 03, 2018 6:27 pm Hope this helps.
Thanks Christian, yes it helps! And my luck that the love of my life studied French, so she has got some work to do. (-;
bart1805
Post by bart1805 »
Hi all,
Yes, it works! Really bad seeing, but I could get fairly easily in focus.
The set up.
Image20180506_112342_resized by bart moors, on Flickr
On the front the 160 mm D-Erf. I made an adaptor out of wood and an old dew cap. And can screw it on to the front of the M703.
Image20180506_112321_resized by bart moors, on Flickr
