Hi all,
Nov 2, was a clear warm day. Seeing was variable from barely
acceptable to good.
I decided to image the sun in Ca II K and H-a.
Telescope is my trusty Celestron 11 280mm F/10 SC equipped with the ARIES
295mm DERF two bands filter and PRG Flea 3 b/w camera.
The Ca K filter is a Double Stacked resulting about 1,5A bandwidth with a very steep transmission curve.
H-a filter is a single stacked.
Thanks for looking.
Valery.
Ca K and H-a through 11" aperture Nov 2 2017
- Nov-2-2017--UT-07h-55m-C11-ARIES-295mm-DERF--CaK-PST-DS-Flea3.jpg (478.93 KiB) Viewed 1102 times
- Nov-2-2017--UT-07h-47m-C11-ARIES-295mm-DERF--PST-Flea3.jpg (470.93 KiB) Viewed 1102 times
- Nov-2-2017--UT-07h-57m-C11-ARIES-295mm-DERF--CaK-PST-DS-Flea3.jpg (494.55 KiB) Viewed 1102 times
- Nov-2-2017--UT-07h-45m-C11-ARIES-295mm-DERF--PST-Flea3.jpg (467.64 KiB) Viewed 1102 times
- Nov-2-2017--UT-08h-54m-C11-ARIES-295mm-DERF--CaK-PST-Flea3.jpg (492.88 KiB) Viewed 1102 times
- Nov-2-2017--UT-07h-32m-C11-ARIES-295mm-DERF--PST-Flea3.jpg (285.9 KiB) Viewed 1102 times
- Nov-2-2017--UT-09h-46m-C11-ARIES-295mm-DERF--PST.jpg (132.54 KiB) Viewed 1102 times
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Re: Ca K and H-a through 11" aperture Nov 2 2017
Hi Valery,
As usual great captures, despite the seeing.
Alfred
Alfred
- Has thanked: 20828 times
- Been thanked: 10502 times
Good results given the conditions Valery, you can tell the seeing is not as good as you normally get.
- Been thanked: 8907 times
- Been thanked: 4434 times
Hi Valery...
These are very good images...even with the variable conditions your capture and processing turned out very well.
- Been thanked: 171 times
- Has thanked: 9327 times
- Been thanked: 6163 times
