Sol 4-11-2017
Ibbo
Has thanked: 2443 times
Been thanked: 1650 times
Sol 4-11-2017
Post by Ibbo »
Awful seeing
60mm Lunt Double stacked with 60mm Coronardo and PGR Chameleon cam
4-11-2017 15-07 mono.png (4.2 MiB) Viewed 1583 times
4-11-2017 15-07 fc.png (12.59 MiB) Viewed 1583 times
eroel
Been thanked: 4959 times
Re: Sol 4-11-2017
Post by eroel »
Steve:
Nice discs, though I think that you have to get rid of the hot spot on the lower left corner.
Have a nice and Sunny Sunday,
Ibbo
Re: Sol 4-11-2017
Post by Ibbo »
Thanks Eric.
Wish i could get rid of it - any tips??
eroel
Re: Sol 4-11-2017
Post by eroel »
Steve:
1-How do you have your system set up?
2-Have you tried the 60mm Lunt without the Coronado etalon?
3-Have you tried the 60mm Coronado etalon?
If both work OK, it is probably an adjustment issue of the second etalon, so I would first try each etalon separately to see if they work fine and get an even solar disc, then I would install the doublé stack etalon and make some test rotating it in front of your Lunt etalon until you get the best position, (don´t know if your Coronado has any adjustment at all) if so, then you will have to deal with that too.
I just have Coronado etalons, some old 40mm made by David Lunt, and also some new ones made by Meade like the 90mm one.
Hope some other friends jump in and let us know what they think,
Ibbo
Re: Sol 4-11-2017
Post by Ibbo »
Thanks Eric
The Lunt is not too bad on Single stack.
Not tried the Coronado as sigle for a good while I will give it a try next time i get more than 30 mins of sun.
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Re: Sol 4-11-2017
Post by yltansg »
Hi Steve,
Wish you all the best in getting uniform disks. Like what Eric mentioned, adjust the single etalon first and then move on to the double-stacked......
Alfred
Has thanked: 20757 times
Been thanked: 10442 times
Re: Sol 4-11-2017
Nice job Steve!
Has thanked: 17925 times
Been thanked: 8894 times
Re: Sol 4-11-2017
Lovely contrast on the features :bow :hamster: It does look like the ghost to me. Have you tried just tilting it a bit to get it just out of shot? My PST is like this, I get maximum on band contrast when the ghost is sat right on top. I have to just tilt it just off disc to image. The contrast suffers a little but not too bad.
Re: Sol 4-11-2017
If you can get a circular polariser between the 2 etalons you'll kill off that reflection https://www.amazon.co.uk/BPLUSWCP77-Cir ... B0000BZLAD
Ibbo
Re: Sol 4-11-2017
Post by Ibbo »
Thats interesting to know.
Any idea of the increse in exposure time???
Re: Sol 4-11-2017
Not sure, there will be some though...
Ibbo
Re: Sol 4-11-2017
Post by Ibbo »
i just need to do a bit of measuring
