My first Scope and Problem!
PlanilAstro
Post by PlanilAstro » Tue Dec 12, 2017 5:56 pm
Hi all
I am PlanilAstro, a new user for Solar Image. I buy Used SolaREDi60 0.5A Solar Telescope from OPT web. It's beautiful when viewed through the Eyepiece lens. But when I applied to CCD to take pictures. It appears to be a pattern similar to noise.
https://photos.app.goo.gl/ZeRqDr9JIRdjksQk1
Image 1 : When the focus is on thin lines. Looks like noise.
https://photos.app.goo.gl/gjmB6IoOgiRXKafU2
Image 2 : When not focus I see the problem show.
I use SolaREDi60 0.5A Scope and ASI290MM CCD , no other filter
Thanks for helping me solve the problem.
PlanilAstro
FlankerOneTwo
Re: My first Scope and Problem!
Post by FlankerOneTwo » Tue Dec 12, 2017 8:18 pm
Welcome to the wonderful world of Newton rings! The bands are an interference pattern produced by internal reflections, often off the camera glass. You will really only see this when imaging narrowband like Ha. I have them very pronounced with Barlows, especially with the ASI1600MM. The most commonly used solution is to tilt the camera slightly. I like the Daystar Interference Eliminator, ZWO also makes one, and there are any number of do-it-yourself solutions.
Cheers,
Patrick
Brendan
Post by Brendan » Tue Dec 12, 2017 8:20 pm
Hi there, the lines are newton rings, it is a common problem with some easy fix's, you could try tilting the camera (my preferred method) or take flats, below is link to an excellent article for solar imaging.
http://solarnutcase.livejournal.com/18572.html
Brendan
Lunt LS50THa with B600 b/f, W/O 72 Megrez, Lunt Herschel wedge, 6" F8 Herschel Newtonian, PGR Grasshopper 3, Opticstar pl131c,
https://www.flickr.com/photos/141439754@N06/
PlanilAstro
Post by PlanilAstro » Wed Dec 13, 2017 2:23 am
Thank you very much for answers from FlankerOneTwo and Brendan
The solution is to tilt the camera slightly. Need an accessory? If there is a link to explain it. Please tell me
I started shooting the sun for the first time. If there is anything I should know. Please tell me.
I will try again.
PlanilAstro
PS. I live in Thailand Response time may be the opposite of your time.
FlankerOneTwo
Post by FlankerOneTwo » Wed Dec 13, 2017 5:43 am
This is the one I use. Easy to adjust on the fly.
http://www.icstars.com/Store/daystar-so ... nator.html
PlanilAstro
Post by PlanilAstro » Wed Dec 13, 2017 6:19 am
Thank! FlankerOneTwo
this device in my link, can solve the problem?
https://astronomy-imaging-camera.com/pr ... t2-tilter/
FlankerOneTwo
Post by FlankerOneTwo » Wed Dec 13, 2017 11:41 pm
I had one of those first, however not quite as easy to adjust when the camera (ASI1600) is mounted. I think the Daystar has more tilt as well - the 1600 needs a lot :-/
It worked fine for the QHY5III 174, though.
PlanilAstro
Post by PlanilAstro » Thu Dec 14, 2017 2:27 am
Thank you very much, FlankerOneTwo
I believe you and order successfully.
Post by Montana » Thu Dec 14, 2017 12:46 pm
A very warm and sunny welcome :hamster:
I think this would be a very interesting read for you viewtopic.php?f=27&t=21719
PlanilAstro
Post by PlanilAstro » Thu Dec 14, 2017 6:11 pm
Thank you very much Alexander, this information is very helpful for me.
Your photos are inspirational for me.
PlanilAstro
Derek Klepp
Post by Derek Klepp » Fri Dec 15, 2017 5:46 am
I had this scope and the filtering unit clouded over so Daystar replaced it.You May want to check this as well.
PlanilAstro
Post by PlanilAstro » Fri Dec 15, 2017 2:48 pm
Thanks Derek Klepp,
PlanilAstro
Post by PlanilAstro » Thu Jan 04, 2018 3:57 am
Thank All Again :)
this is a First Light my Scope
https://drive.google.com/file/d/1MRWksK ... sp=sharing
FlankerOneTwo
Post by FlankerOneTwo » Thu Jan 04, 2018 5:50 am
Looks great - glad you got things working!
-Patrick
Post by Montana » Thu Jan 04, 2018 7:54 am
Fantastic!
:bow :hamster:
Users browsing this forum: Bing [Bot] and 3 guests
