Sun 24-12-2017
rsfoto
Sun 24-12-2017
Post by rsfoto » Sun Dec 24, 2017 9:07 pm
Finally after many weeks of a Sun drought I was able to make a mosaic of 9 images. For full size view ~ 2300px square please open in new window or tab.
Somebody asked a few weeks ago about automatic stitching with Photoshop.
Well PS CS6 failed to make a mosaic but AutoStitch did it with no problems at all. Look below at the PS CS6 Frankenstein mosaic
Raw material for both software were the same images.
Re: Sun 24-12-2017
Post by ffellah » Sun Dec 24, 2017 11:14 pm
That mosaic came out really well, Rainer. Nice detail and prominences...
rsfoto
Re: Sun 24-12-2017
Post by rsfoto » Sun Dec 24, 2017 11:48 pm
Thank You :bow2
Re: Sun 24-12-2017
Post by MapleRidge » Mon Dec 25, 2017 1:42 am
Hi Rainer...
Great mosaic :bow It's always a challenge to get the separate frames to match up but this one turned out well.
rsfoto
Re: Sun 24-12-2017
Post by rsfoto » Mon Dec 25, 2017 5:00 pm
Hi Rainer...
THank You Brian
Yes and before every session I check the stacked etalons in order that they give me a uniform surface. That mosaic is made from 9 images.
I am using a double stacked 60mm Coronado (the very old ones) which were matched manually when Coronado was still Coronado and not Meade.
They are sitting on a Takahashi FSQ 85-ED and a BF30 blocking filter. The etalons are rotated 90 degrees to each other and I can adjust via stepper motors with a very fine tuning. So I can see the changes of the hotspot and center both. Normally using one etalon you normally get an elliptical hot spot but with 2 I found out the 2 eliptical hotspots do make a more uniform illumination of the surface of the Sun.
I use a Canon 2X extender and so I go up to 900mm focal length when making the mosaic.
My camera is a very old Lumenera 2-2M and I use Lucam Recorder for image acquisition. The program has a so called False Colour Mask and so I can get the prominences on the limb of the Sun as well as the surface details in one single shooting. No need to assemble 2 images. The color as you see the image comes out of the camera like that.
eroel
Re: Sun 24-12-2017
Post by eroel » Mon Dec 25, 2017 7:10 pm
Rainer:
A very nice mosaic using the Lucam Palette.
Remember that long time ago you configured a pallet for me? well, I still can not make it work as good as yours so I will call you when back home so you can explain me again your workflow.
Felices fiestas y abrazo,
Re: Sun 24-12-2017
Post by Carbon60 » Tue Dec 26, 2017 8:54 am
Nice comparison, Rainer.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Re: Sun 24-12-2017
Post by marktownley » Tue Dec 26, 2017 9:35 am
Lovely disk Rainer!
rsfoto
Re: Sun 24-12-2017
Post by rsfoto » Tue Dec 26, 2017 4:43 pm
Thank you Stu and Mark.
Re: Sun 24-12-2017
Post by Montana » Tue Dec 26, 2017 5:17 pm
Another wonderful image :bow
In Photoshop you need to load the plugin so that you have 'interactive' mode in the Photomerge, then you place the panels where you want them to be and Photomerge does the blending.
rsfoto
Re: Sun 24-12-2017
Post by rsfoto » Thu Dec 28, 2017 3:00 am
Hi Alexandra,
Where can I find that Plug in ? I have PS CS6
Thanks
rsfoto
Re: Sun 24-12-2017
Post by rsfoto » Thu Dec 28, 2017 3:57 am
Hi Alexandra,
Thanks
Hi Alexandra,
Thank You very very much :bow2
I found the Plug In, Installed it and yes it works quite good. Just made a test and looks very good.
Here the Full Disk mosaic from the Suns of today made with the Photomerge Interactive UI
:bow
rsfoto
Re: Sun 24-12-2017
Post by rsfoto » Thu Dec 28, 2017 4:13 am
Just tried again the Photomerge UI Plug In for the failed FD mosaic and here is it using the Plug In. Works nice :seesaw
Re: Sun 24-12-2017
Post by Montana » Thu Dec 28, 2017 4:50 pm
:hamster: looks like you are having fun :hamster:
rsfoto
Re: Sun 24-12-2017
Post by rsfoto » Thu Dec 28, 2017 5:15 pm
Sue I am and I start to like that tool
:bow2
Users browsing this forum: No registered users and 14 guests
