Good day everyone...
A clear day on Wednesday this week, and time to do a quick session over lunch. The weather has warmed up too...now -6C may still be cold to most but it is 20C warmer than the last day I was out
It was nice to see some activity at the eyepiece in the LS80T/B1200/LS75FHa double stack solar scope, with some filaments and once AR nicely placed on the disk. There were many small proms that show in the images, but they were not visible to the eye.
The images below are disk/limb monochrome composites, the first with positive disk and limb exposures, the second is inverted, and the third is a negative disk and positive limb:
As clouds rolled in I tried to grab some white light images of AR2696, but the only one that worked was at prime focus on the iStar 150mm, f8 scope through the Lunt solar wedge/Baader continuum filter:
A short session, but I will take what I can these days!
17 January
- Has thanked: 65 times
- Been thanked: 4444 times
17 January
- Has thanked: 9369 times
- Been thanked: 6193 times
Re: 17 January
A lovely set, Brian. I like all those small prominences, how you caught 2696 and the full disks !
Looks like you had a very nice session. I can't believe that these days we have to be happy about these microscopic sunspots .
I want my money back.
- Has thanked: 18050 times
- Been thanked: 8914 times
Re: 17 January
These are super Brian the fine details are beautiful and the new AR is very promising. I imagined you imaging in your Hawaiian shirt and a cocktail in hand
- Been thanked: 5006 times
Re: 17 January
Brian:
Nice session, you got all those small prominences beautifully.
Re: 17 January
Franco, Alexandra, and Eric...
Thanks for your comments and feedback...always appreciated!!!
With options to use WL, HA, and CaK there is usually something to be seen even during the solar doldrums. I got my first Ha equipment 10 years ago I believe as we were in a relatively quiet time then as well.
Alexandra...I'll hold out for another 20C or so before going to short sleeves, but I need more than one cocktail to get into me before any Hawaiian shirts are worn Right at the 0C mark today, and the sun came out after I left home at lunch
- Been thanked: 171 times
Re: 17 January
Cheers Brian the last Ha is my favourite .I have been enjoying cooler temp here in the 20s before they skyrocket again.
- Has thanked: 20908 times
- Been thanked: 10564 times
Re: 17 January
Excellent set of images Brian!
Re: 17 January
Derek and Mark...
Thanks fro your comments, they're always appreciated
- Has thanked: 8587 times
- Been thanked: 8322 times
Re: 17 January
Excellent images, Brian.
Re: 17 January
Thanks Stu !!!
