Keeping the Sun in the eyepiece
denababy
Post by denababy » Wed Jan 31, 2018 12:56 pm
Hi there I have just spent a few hours setting up my eq3-2 tripod and Lunt 50ha, pointing to the North, I have marks on the floor put there one night after getting polar alignment I balanced everything as close as I could then using the hand controller I moved the scope to line it up with the Sun and set the hc to Solar tracking. I charged my battery over night. The reason I did it so very carefully was to try to have the tracking spot on so that when the clouds give us a decent break I can get some good data but sadly, although not a long way off it was off a bit. Anyone advise on how to get perfect tracking.
Re: Keeping the Sun in the eyepiece
Post by Montana » Wed Jan 31, 2018 3:05 pm
You will never get perfect tracking but then it is not necessary either. If you are watching by eye then you can make tiny adjustments, if using a camera then sometimes a little drift can help eliminate Newton's Rings :) The amount it moves will not ruin your images as exposure time is so fast anyway. If however you want to take a timelapse and want to go away for 2hrs and leave it running then you would have to use a Hinode Solar guider. But I tend to sit and watch for 2 hrs instead and make micro adjustments (I like staring at the Sun).
This is how I align my tripod https://www.flickr.com/photos/alexandra ... 535593245/
Be sure to read all the comments!
Users browsing this forum: yltansg and 10 guests
