Sunday Sunshine - 4th February
Has thanked: 20757 times
Been thanked: 10442 times
The clouds parted (well there were gaps) and old yellow face appeared in and out in a dancing and teasing fashion. The good news is he's now pretty much cleared the trees so weather permitting for me the 2018 solar season has begun, on, an albeit at the moment weekend basis. Still need to iron out the tuning on the DS50 and a blocking filter reflection to sort out, but, for the moment that's just tweaking some mechanics when the sun is out for long enough to do so.
Till then, first sun in a month, DS50 and PGR Ch3, bit of barlow to get a full frame.
Imageha-full-disk-bw by Mark Townley, on Flickr
Imageha-full-disk-colour by Mark Townley, on Flickr
Next weekend off to Anglesey, if weather looks promising a full solar armoury will be taken. If its cloudy i'm going to the pub.
Has thanked: 9298 times
Been thanked: 6133 times
Re: Sunday Sunshine - 4th February
Post by ffellah »
That is a great shot with good detail, Mark ! Nice to have started the season with this.
Franco :beanie:
robert
Has thanked: 4 times
Been thanked: 1275 times
Post by robert »
Nice (prom on the east limb too)
Robert
Has thanked: 17925 times
Been thanked: 8894 times
Nice surge prom! glad you had your first taste of the season :hamster: :bow I had to go to work all day :(
Thanks everyone! Fingers crossed the weather improves soon so we can see more of old yellow face.
Has thanked: 8523 times
Been thanked: 8259 times
Post by Carbon60 »
Nice one, Mark. Good to see the solar season has begun for you.
eroel
Been thanked: 4959 times
Post by eroel »
Mark:
Looks like you are on again.
Nice set of FD´s.
rsfoto
Has thanked: 9694 times
Been thanked: 5760 times
Post by rsfoto »
Good Mark,
What is a DS50 ?
saludos Rainer
Thanks guys! The DS50 is a double stacked Lunt 50 Rainer :)
rsfoto
Post by rsfoto »
marktownley wrote: Mon Feb 05, 2018 7:48 pm Thanks guys! The DS50 is a double stacked Lunt 50 Rainer :)
Thanks Mark
I see the Lunt 50mm scope has a etalon inside and for double stacking you add on the fronmt anotjer etalon. I see you have the hotspot decentered.
¿ have you tried rotating the front etalon in order to center more the hotspot and so have a more even sun surface ?
I did that with my 2 Coronados and for fixing the position i put some rounds of electrical tape around them. Now they have an offset of 90°
saludos Rainer
Hi Rainer,
Yes, there is an off centre hot spot. I've only had the scope since the start of winter, and this is the 3rd or 4th time i've been able to use it so any views have been fleeting with no time for experimenting with the low sun catching gaps in between the trees and buildings. Hopefully as the year progresses and the sun gets higher it will allow me to experimenting more. Clocking the external etalon is on my list, was something I did with my Coronado DS40. I also have a ghost which is blocker / barlow related that needs dealing with too. My other thought is that off centre hot spots are a result of collimating and or refocusing lenses not sat orthogonal to the optical axis. Other than changing the focuser and running with a coronado blocker i've actually done nothing in the way of tweaks or mods to the scope, which, is very unusual for me! I have no doubt that I will :D
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
Cheers Mark good to see you up and imaging .I do like your back up plan.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Mark...
Nice to see your results of the DS50...nicely detailed and I know you will get the fine tuning ironed out !!!
If you have to resort to the pub, have a scotch ;)
